Battery issues!!!!!!!!1 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 08-08-2009, 11:51 PM Thread Starter
96 Ford F-350 PSD
Ford3544's Avatar
I have 2 redtop optima batteries (34/78) relocated to the tool box in the bed and this is the second pair that will never hold a charge. If the truck sits for more than 2-3 days then I have to put the charger on it to start the truck. I have installed a 200amp alt to help with the load, and it still doesn't help.
I am just wondering if I have the right size wires running from the starter/starter relay to the batteries? I have two 1gauge wires that run all the way to the starter/starter relay and then one 1gauge that goes to the frame and then from the frame to the block. Charging system says that it is charging.
Any Help?
96 Ford PSD! Custom intercooler, 01 Aluminum radiator, S&B Intake, 5" exhaust, Stage 2 injectors, Complete stud kit, 3" aluminum intake plenums, Fuel system w/aeromotive pump and regulator, Coolant filter, BTS Trans, Adrenaline HPOP, live tuned DP Tuner, 4" lift, MKW19 wheels and Toyo MTs.
Ford3544 is offline
post #2 of 15 (permalink) Old 08-08-2009, 11:54 PM
Starting Over
kainers's Avatar
Re: Battery issues!!!!!!!!1
I thought you needed 00 wire for battery connections?
kainers is offline
post #3 of 15 (permalink) Old 08-09-2009, 12:23 AM
Don't EFN worry about it
Aljay's Avatar
Any Help?
Red tops have gone down hill the last one I owned did not last.
Tuned by T Wildman
Aljay is offline
post #4 of 15 (permalink) Old 08-09-2009, 12:47 AM
mwalsh9152's Avatar
have you checked for a slow draw on the batteries? When you say 1 gauge, do you mean 1/0? either way that should be more than enough
If it doesnt have a draw I would probably say that you have a problem with the batteries
mwalsh9152 is offline
post #5 of 15 (permalink) Old 08-09-2009, 12:51 AM
original "REZNECK"
kbnord's Avatar
you can always get them charged up and load test them one by one
twice tottalled
01 F250 cc 4x4 straight pipe, custom front and rear bumpers, 1 ton rear susp, flatbed, TS Chip, king ranch rims, 315 tires
Originally Posted by Aljay
Since when do 7.3's puke coolant like an overfilled hooker on a busy night ?
kbnord is offline
post #6 of 15 (permalink) Old 08-09-2009, 02:19 AM
^^^^^ +1. Disconnect both negatives after running it next time; see if they discharge over time.
madpogue is offline
post #7 of 15 (permalink) Old 08-09-2009, 04:22 AM Thread Starter
96 Ford F-350 PSD
Ford3544's Avatar
I have charged them this afternoon. I am going to see what happens. I found a few gauges that I installed that I put on a constant power instead of key on. So who knows. I am not liking the Optima's!!!!!!!!!!
Ford3544 is offline
post #8 of 15 (permalink) Old 08-09-2009, 04:30 AM
RDRCM
CooterBrown's Avatar
#1 is on the small side. I use 2/0 on all battery relocates. Voltage drop plays a huge roll.
#49
Sold
2006 Almighty CumminGs
CooterBrown is offline
post #9 of 15 (permalink) Old 08-09-2009, 11:28 PM Thread Starter
96 Ford F-350 PSD
Ford3544's Avatar
What batteries are you guys running?
Ford3544 is offline
post #10 of 15 (permalink) Old 08-10-2009, 01:31 AM
Every optima i have used has more than payed for itself many times over, so i dont know where you guys are getting off talking about the quality of optimas going down. You have to have the correct size battery matched to your application of course, which i hope you have. Any constant drain on your battery will cause it to go dead. Plain. Simple. And you should be happy you have bought optimas because they ARE DESIGNED to go from fully charged to depleted over and over again. A regular battery would of gone belly up by now in your application.
So i would advise you make double sure, everything in your charging system is hooked up correctly, including your isolators for the dual battery setup, correct wire gauge, connections, whatever accessories you have on your rig...etc.
And if you have a question about what could be possibly draining the batteries you should fill us in on what extra equipment you have on your electrical system; extra accessories.
Optimas or Odessy's are what i use.
1995 Reg Cab 2wd LB--Baby Swamps/SBC Con OFE/Ts 6pos/ Swamps tunes/ Intake/ Exhaust/ No lift on 35's
4runner buggy, on 4d's, chevy 4.3 cpi/4l60e, 5.71's, Doubler with 4.7 rear case, linked rear, longs...etc
Scottapher is offline
