Clutch pushrod fix. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 08-08-2009, 06:57 AM Thread Starter
Clutch pushrod fix.
Has any body done the perminate bushing fix from Ebay ?
They call for an open 11/16 box wrench for the bolt holding the rod that the bushing goes on to, connected to the clutch pedal
But none of my 11/16 wrenches or sockets fit..
Any body done this know what size I need? 18 MM fits close, but she wiggles a bit
96'
F250 Some stuff
Bamboo is offline
post #2 of 21 (permalink) Old 08-09-2009, 01:44 AM Thread Starter
Re: Clutch pushrod fix.
So incase any body is planning on this
I had to use the 18 MM with a little wiggle room, I dont know why, But It worked good enough..
finally got it all back together, and man the first light tap from the foot begins engaging the clutch, Unlike I've ever felt before!
so Test drive in a hour, Can't wait to actually mash on the clutch without worrying about it breaking or dropping to the floor
96'
F250 Some stuff
Bamboo is offline
post #3 of 21 (permalink) Old 08-09-2009, 03:36 AM
oilfield trucker
zpilgeram's Avatar
Are you talking about under the steering wheel, down on the brake and clutch pedal assembley ? If so please explain. I've had problems with the clutch not working rite and having to shove your foot through the floor board to get it to start. Where is this at on E-bay ?
zpilgeram is offline
post #4 of 21 (permalink) Old 08-09-2009, 03:47 AM
original "REZNECK"
kbnord's Avatar
11/16 is the same as 17mm
twice tottalled
01 F250 cc 4x4 straight pipe, custom front and rear bumpers, 1 ton rear susp, flatbed, TS Chip, king ranch rims, 315 tires
Originally Posted by Aljay
Since when do 7.3's puke coolant like an overfilled hooker on a busy night ?
kbnord is offline
post #5 of 21 (permalink) Old 08-09-2009, 04:21 AM
Senior Veteran Member
Centxdiesel's Avatar
Garage
Yes, a good permanent fix for the little white plastic bushing that always breaks apart I have read. I want to do this too someday.
Centxdiesel
1997 F250 XL SC, 512HP 1019TQ,
30% nozzle Hybrids from [email protected]
Adrenaline, Beans D-66,Beans E-Fuel,Valair Ceramic-Kevlar clutch.
Awesome Tuning by: Matt: from:
Centxdiesel is offline
post #6 of 21 (permalink) Old 08-09-2009, 04:52 AM
Clouse2411's Avatar
Send a message via AIM to Clouse2411 Send a message via Yahoo to Clouse2411
I need more info. $10 a bushing is getting bad when i have to put one in every 2 weeks.
97 F-350 RC LB.
Farmer's 400/400, Irate T-4 Mount And Regulated Return, Bullseye S475, ARP Main And Headstuds, Valair Double Disc, Intercooled, Short Throw Shifter, 4in Lift, Hood Stack, Black Interior, Autometer Gauges, Scan Gauge, Front And Rear Diff Covers, Dodge Tow Mirrors, 36x15.50x18 ATZs
Clouse2411 is offline
post #7 of 21 (permalink) Old 08-09-2009, 05:16 AM Thread Starter
Thanks.. but the 17mm didn't fit either, yet the 18 fit better than the 3/4
Sorry, didnt seem like many people were interested ..
Its a sweet fix, works so much better, And will take abuse
FORD Clutch Rod End PERMANENT Repair powerstroke too. :eBay Motors (item 260457521449 end time Aug-09-09 15:25:45 PDT)
- - -> for making such a ridiculous part on a sweet truck
96'
F250 Some stuff
Bamboo is offline
post #8 of 21 (permalink) Old 08-09-2009, 05:52 AM
OverFuelingForYourPlesure
pontiacross's Avatar
I have one on my truck. its been going stong for almost 4 years now!
old stile
new fix
Ross
2.6 modified street pulling truck "The Lone Stroke
-1996 f350, stock bottom end! swamps 400/400% injectors, swamps BFH turbo, swamps IDM, Swamps tunes, BTS oil, springs, studs, tubes, fuel system, water to air cooler, and much more...
-97 f350 4x4 CCLB tow rig
pontiacross is offline
post #9 of 21 (permalink) Old 08-09-2009, 01:28 PM
Birdman71's Avatar
Send a message via AIM to Birdman71
I just did mine last week,took all of 30min!{Thats using a hacksaw} No more plastic bushing for me.its a great improvement!
Birdman71 is offline
post #10 of 21 (permalink) Old 08-09-2009, 06:28 PM
i just drilled through the cross- shaft and put a pin through the hole to keep the clutch rod in place....cost $0.00 and took all of 2 mins.
1995 Reg Cab 2wd LB--Baby Swamps/SBC Con OFE/Ts 6pos/ Swamps tunes/ Intake/ Exhaust/ No lift on 35's
4runner buggy, on 4d's, chevy 4.3 cpi/4l60e, 5.71's, Doubler with 4.7 rear case, linked rear, longs...etc
Scottapher is offline
