MANIFOLD LEAK - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 08-07-2009, 03:14 PM Thread Starter
Cowboy Up
MANIFOLD LEAK
What is the best way to remove the bolts without breaking them and replace the gasket? Also, how many bolts are there on the driver side so I can get my parts ordered?
'96 F350 CCLB, Dually, 4wd, ZF6, 4.10's, 4" lift, Energy suspension and body bushings, Firestone airbags, 245/70R19.5, 3" DP, 4" MBRP straight pipe, Afe stage 2, TW 6 pos, Autometer gauges, Valair kevlar/ceramic clutch, Stage 1's, Shimmed FPR, Gutted EBPV, Welded pedestal, CCV mod, SD 7.3 intercooler, D66 Turbo, 17* HPOP
INTPSTROKE96 is offline
post #2 of 11 (permalink) Old 08-10-2009, 01:53 PM
Cratos's Avatar
Re: MANIFOLD LEAK
lots of BP Blaster ??
Blue 2012 XLT SCLB 4X4 , 38,550 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter.
Cratos is offline
post #3 of 11 (permalink) Old 08-10-2009, 02:43 PM
Senior Member
Larry_Dubya's Avatar
Re: MANIFOLD LEAK
Yeah lots of Blaster and let it soak for a couiple days keep squirting it down. Couldn't tell you how many bolts.
'97 F-350 4-WD
E4OD 3.55 gears
7.3 I-C stage 1's
38R
Termy modded 17*
Tru-Cool 4739
Swamps IDM Mod
Larry_Dubya is offline
post #4 of 11 (permalink) Old 08-10-2009, 04:41 PM
screw the DARK SIDE
97strokn&smokn's Avatar
Re: MANIFOLD LEAK
You might have have to use a little heat to . i have changed a couple where only heating the bolts up with a torch would work. good luck
97strokn&smokn is offline
post #5 of 11 (permalink) Old 08-11-2009, 02:41 AM
mwalsh9152's Avatar
Re: MANIFOLD LEAK
I just got my engine out of the truck tonight, throughout the day I soaked the manifold bolts as best as I could with PB Blaster while it was in the truck. Once I had it out I quickly went around and cracked all but three of them loose, I resoaked the others and will try it again tomorrow with a little heat.
Heres another question for you guys. How reliable are the gaskets, would I be better off taking the manifolds to a friend to have them machined and just bolt em back on with new bolts instead of gasketing?
mwalsh9152 is offline
post #6 of 11 (permalink) Old 08-11-2009, 03:05 AM
OverFuelingForYourPlesure
pontiacross's Avatar
Re: MANIFOLD LEAK
have them machine and use aftermarket gaskets. the IH ones are just a thin piece of steel. the aftermarket ones have a little crush to them to take up for wear on the head
Ross
2.6 modified street pulling truck "The Lone Stroke
-1996 f350, stock bottom end! swamps 400/400% injectors, swamps BFH turbo, swamps IDM, Swamps tunes, BTS oil, springs, studs, tubes, fuel system, water to air cooler, and much more...
-97 f350 4x4 CCLB tow rig
pontiacross is offline
post #7 of 11 (permalink) Old 08-11-2009, 03:32 AM
mwalsh9152's Avatar
Re: MANIFOLD LEAK
from what I read I thought that they came from the factory without a gasket?
post #8 of 11 (permalink) Old 08-11-2009, 06:08 AM
Re: MANIFOLD LEAK
yea they were metal to metal from the factory
Ross
post #9 of 11 (permalink) Old 08-11-2009, 03:11 PM Thread Starter
Cowboy Up
Re: MANIFOLD LEAK
I started pulling it apart last night, got all but one out. I soaked it some more and will try again today. I was going to put a IH gasket on with all new bolts. Will that not hold up or should I be ok?
post #10 of 11 (permalink) Old 08-11-2009, 08:39 PM
mwalsh9152's Avatar
Re: MANIFOLD LEAK
my question is if they are just metal to metal from the factory, if I resurface the manifolds do I need to use a gasket, or can I put them back on without the gasket
