AC Problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 08-06-2009, 11:47 PM Thread Starter
cchildress's Avatar
AC Problem
I looked around and couldnt find much. My AC blows cold and then blows warm at idle or driving it doesnt matter. I went to a shop today and he put gauges on it and (I dont know much about AC's) I think the high side was like 375 or something and he said that was way to much so he let some out and now it only blows warm. He said he can get to it monday.
Im just trying to figure out what could be the problem and learn a lil about my AC system. I think my orfice tube might be clogged but it hasnt been on there that long.
Thanks, Cody
97 F350, lwb, cc, 4x4
Mods-lots!! To many to list and more to come!!!
Deathrow Inmate #26
cchildress is offline
post #2 of 21 (permalink) Old 08-07-2009, 12:09 AM
PSN Mega Miler
crowz's Avatar
Re: AC Problem
375 is high but you might want to check the clutch too.
Check the gap on the clutch. If it looks like you can get more than a sheet of paper in there when the a/c is off then the clutch needs adjusting or replacing.
Clogged orifice usually doesnt come and go.
I caught mine by seeing the compressor wasnt turning over when it was in one of its hot air blowing moods.
It will drive you nuts trying to find the problem if its the clutch.
All I had to do on mine was remove the shim from the clutch by removing the 6mm(I think) bolt from the front of the compressor and pulled the face of the clutch off by hand at the point and removed a shim from it and put it back together. Works great now. Was randomly stopping cooling but blew ice cubes when it did work.
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
post #3 of 21 (permalink) Old 08-07-2009, 12:22 AM Thread Starter
cchildress's Avatar
Re: AC Problem
That is exactly what mine is doin when its cold its cold but then will get warm. But now that he let some out it only blows warm/cool.
What does pulling the shim out do? It is a napa compresor and has that lifetime warrenty thing I think. I may just take it in a switch them out. I have noticed a residue of oily grime showing up on my hot side ic pipe and top radiator hose like the compresor is throwing oil out when spinning.
Thanks
Deathrow Inmate #26
post #4 of 21 (permalink) Old 08-07-2009, 01:37 AM
FREE THINKER
Chip's Avatar
Re: AC Problem
Take the front plate off..clean the front of the compresorand plate..take the shim out(looks like a washer)
this vid should help
Chip is offline
post #5 of 21 (permalink) Old 08-07-2009, 03:12 AM Thread Starter
cchildress's Avatar
Re: AC Problem
Well guys yall impressed me once again. Yall are the guys!!!!!!!! This is why I love this place!!!!!!!
THANKS, Cody
Deathrow Inmate #26
post #6 of 21 (permalink) Old 08-07-2009, 03:13 AM Thread Starter
cchildress's Avatar
Re: AC Problem
It worked I had two shims in mine and only took one out.
Deathrow Inmate #26
post #7 of 21 (permalink) Old 08-07-2009, 06:17 AM Thread Starter
cchildress's Avatar
Re: AC Problem
Well it worked for a lil while and then back to warm ugggh.
Deathrow Inmate #26
post #8 of 21 (permalink) Old 08-07-2009, 06:32 AM
PSN Mega Miler
crowz's Avatar
Re: AC Problem
You need to go by the gap if thats whats causing it. How big of a gap is there after taking one shim out?
Mine has no shims in it now.
crowz is offline
post #9 of 21 (permalink) Old 08-07-2009, 03:50 PM Thread Starter
cchildress's Avatar
Re: AC Problem
About a papers width. Maybe a lil more. I could def see where it has been wearing down. For only being on there almost a year its alot it looks like. Today it got cooler again. This thing is very tempermental lol.
Deathrow Inmate #26
post #10 of 21 (permalink) Old 08-07-2009, 04:46 PM
THE ONE AND ONLY!
Big K's Avatar
Send a message via AIM to Big K Send a message via MSN to Big K Send a message via Yahoo to Big K
Re: AC Problem
What are the TEMPS? Cool/Cold/Warm....are just RANGES.....really hard to diagnose without the tools
I use these...they work great
375 is WAY HIGH....check this for details
Kevin "Big K" Neal
President and Webmaster
North Texas Power Stroke Association
972-768-7252
Big K is offline
