7.3 swap need help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 08-06-2009, 04:56 AM Thread Starter
Red face 7.3 swap need help
I'm out of my comfort zone on this one. My buddy has a 92 F350 with a 460 he bought a 95 Powerstroke engine to replace it. The truck is a manual and the engine is set up for a auto. Do we need to modify the engine harness or the ECM programing for the manual tranny? Will a 6 speed bolt up to the older engine? Please help I'm lost on this.
Cummins Guy is offline
post #2 of 7 (permalink) Old 08-06-2009, 05:05 AM
sick97psd1's Avatar
Send a message via AIM to sick97psd1
Re: 7.3 swap need help
You will need a PCM for a manual, I'm not sure on the wiring harness but my guess is you will have to modify it. And yes a 6spd will bolt right up.
sick97psd1 is offline
post #3 of 7 (permalink) Old 08-07-2009, 02:17 AM Thread Starter
Thanks for the help I'll see if I can find one
post #4 of 7 (permalink) Old 08-07-2009, 02:53 AM Thread Starter
Can I have the PCM reflashed? If not were can I find the one I need I found that there are 4 options to choose from.
post #5 of 7 (permalink) Old 08-07-2009, 03:44 AM
original "REZNECK"
kbnord's Avatar
did he buy just a motor and no harnesses no computers doesnt sound like fun. just did a 95psd into a 96 460 we had both trucks tho.. you will probably need all the harnesses. the fuel tanks. or atleast those harnesses. lots of work ahead of you good luck
twice tottalled
01 F250 cc 4x4 straight pipe, custom front and rear bumpers, 1 ton rear susp, flatbed, TS Chip, king ranch rims, 315 tires
Originally Posted by Aljay
Since when do 7.3's puke coolant like an overfilled hooker on a busy night ?
kbnord is offline
post #6 of 7 (permalink) Old 08-07-2009, 04:56 AM
oilfield trucker
zpilgeram's Avatar
you will need to pull the dash and change the wiring harness, pull the radiator support, Tranny, wiring harness to the rear of the truck, install extra battery box ,washer fluid and radiator overflow, cut off extra bracket on motor mount support, install fuel selector switch and change fuel lines around, pull fuel tanks, change out gauge cluster, exhaust. And thats just the stuff i can remember off the top of my head. If i ever had the chance to do it agian I think i'd rather develop a case of the swine flu.
zpilgeram is offline
post #7 of 7 (permalink) Old 08-07-2009, 04:43 PM
I got a manual PCM if your interested.PM me if you want it.
97 f350 xlt 4x4
dieselthrash is offline
