steering noise - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 08-03-2009, 10:37 PM Thread Starter
kurtfromct's Avatar
steering noise
when i was driving today i heard a knock come from around the front wheel of my 350. i heard it when turning on to 1 of my friends roads so i turned the music down, and while driving i continued to hear the noise every so often. even when turning the wheel very little or going over a bump i got the knock sound. on the way home the noise continued. i was wondering what u guys thing the noise may be. the truck doesnt pull to a side when i drive its just that noise. im guessing its got to be something like ball joints, u-joints, tie-rods, or something. not really sure though.
1997 F-350 7.3 POWER STROKE. XLT, 4X4, BLACK, REG CAB, STRAIGHT PIPED, DIAMOND PLATE TOOL BOX AND BED RAILS
SOLD
kurtfromct is offline
post #2 of 3 (permalink) Old 08-10-2009, 06:26 PM
Why Not's Avatar
Re: steering noise
My truck was doing that when I turned from left to right and also when the suspension moved at any bump in the road. My problem was the front shackles in the frame were bad. I fixed the problem by installing the shackle reversal kit on the truck. The noise is gone and the trucks drives great. If you shacke bushings are bad you should be able rebuild them and fix the problem.
Why Not (Chris)
94.5 Ford F350 4X4 Crew Cab 7.3 PSD 5 Speed / Intercooled / 3" down tube / 5" exhaust from down tube to tail pipe tip (open) / 4" skyjacker lift with Sky Manufacturing shackle reversal and shackle flip kit /4.11 gears / 6-position Hydra Chip / Stage II's
Why Not is offline
post #3 of 3 (permalink) Old 08-10-2009, 11:36 PM Thread Starter
kurtfromct's Avatar
Re: steering noise
Why Not (Chris)
hey thanks a lot i didnt even think about that
SOLD
