HPOP harness conncetor - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 08-03-2009, 04:44 PM Thread Starter
Cratos's Avatar
anyone have a sorce and part # for the connector on the back of the HPOP ? I need to replace it but do not want to get a hole new harness.
Blue 2012 XLT SCLB 4X4 , 38,550 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter.
Cratos is offline
post #2 of 10 (permalink) Old 08-03-2009, 08:27 PM
97 OBS PSD
Aaron Ford's Avatar
Re: HPOP harness conncetor
Like this?
I found it here. http://cgi.ebay.com/ebaymotors/Ford-...Q5fAccessories
Gawd I hope this works...
Aaron
97 PSD 4X4 250K, Ron Holland/Banks 1.00 A/R, EBPV Delete, 3" DP, Kitty Delete, PHP Phoenix 6 POS, 140V IDM, Autometers on the Pillar,4" Intake, 17 degree SD pump, 18-20 psi depending on setting...
Aaron Ford is offline
post #3 of 10 (permalink) Old 08-03-2009, 08:37 PM Thread Starter
Cratos's Avatar
that looks like it.
Cratos is offline
post #4 of 10 (permalink) Old 08-04-2009, 02:58 AM
96P_Stroke4x4's Avatar
wow, that's the right part but i think it was less than $20 at international. don't quote me on the price though
fyi, the part number is 2501107C1
'96 F-250 XLT,x-cab,4x4,BTS,363k,dana60,Swamps175/173s,Dieselsite Adrenaline HPOP,CPR Fuel system,rear discs,4" dp to 6" exhaust,twin 6" stacks,Tymar, Boost Pyro Tranny and white-faced gauges,I/C,onboard air,HX mod,TW 6-position chip
96P_Stroke4x4 is offline
post #5 of 10 (permalink) Old 08-04-2009, 03:05 AM
If the parts guy at the counter is any good... there's a book that has pictures of all the various connectors, organized by number of pins. So you need a 2 pin IPR connector, bring it in and he can look at the pictures till he finds it. (that whole harness unplugs from a 6? pin connector on the left side of the fuel bowl).
That's what he did when I needed to replace the clutch interlock switch connector. I brought it in, he looked under the pictures of 6 pin connectors (even parts guys can figure out a picture), and voila there it was. $38 later I was good to go. The new one had wire leads, it also came with some heat shrink and some crimp connectors to attach to the existing wires.
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air, Beans tunes on VA 4 position chip, Adrenaline HPOP, VDO boost/pyro/outside temp gauges, Ford digital AIC, DPPI downpipe, gutted EBPV, modded turbo ped, Con OFE, add-a-leafs front/rear, Monroe Reflex shocks, Milemarker 449SS hubs...coming soon: 6.0 IC...wish list: Stage 2's
nashvillebill is offline
post #6 of 10 (permalink) Old 08-04-2009, 03:32 AM
What else?
smokyred's Avatar
I got my from IH, Cummins also makes a repair connector that is exactly the same, for a WIF sensor IIRC.
Dave
smokyred is offline
post #7 of 10 (permalink) Old 08-04-2009, 02:36 PM Thread Starter
Cratos's Avatar
22.00 and in stock thanks :)
Cratos is offline
post #8 of 10 (permalink) Old 08-05-2009, 02:31 PM Thread Starter
Cratos's Avatar
Got the connector and two new pins. I gutted the harness ( needed to anyway since I have electric system anyway) now just the two wires for the IPRV Nice and clean.
Cratos is offline
post #9 of 10 (permalink) Old 08-05-2009, 02:57 PM
Don't EFN worry about it
Aljay's Avatar
Tuned by T Wildman
Aljay is offline
post #10 of 10 (permalink) Old 08-05-2009, 08:05 PM
Yep, I did same thing, eliminated all the extra wires and the multipin connector on the passenger side of the fuel bowl. Cleaned up things nicely.
