Any of you guys ever see this? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 08-02-2009, 11:15 PM Thread Starter
kurtfromct's Avatar
was online and came across this:
1997 F-350 7.3 POWER STROKE. XLT, 4X4, BLACK, REG CAB, STRAIGHT PIPED, DIAMOND PLATE TOOL BOX AND BED RAILS
SOLD
kurtfromct is offline
post #2 of 17 (permalink) Old 08-02-2009, 11:18 PM Thread Starter
kurtfromct's Avatar
Re: Any of you guys ever see this?
it says, "waste-gated turbo for improved low end / lugging." how do they figure this? how does a waste-gate effect a turbo's low-end response?
SOLD
post #3 of 17 (permalink) Old 08-02-2009, 11:32 PM
PowerHungry's Avatar
Neat find! Honestly, Cummins made some very good arguments in this ad.
PowerHungry is offline
post #4 of 17 (permalink) Old 08-03-2009, 01:59 AM
oil burner
tughill283's Avatar
my powerstroke is a pile of crap i guess.
tughill283 is offline
post #5 of 17 (permalink) Old 08-03-2009, 02:02 AM
oil burner
tughill283's Avatar
waste gated turbos make more boost at lower rpms and the waste gate opens at high rpms to prevent overboost and turbo destruction.
post #6 of 17 (permalink) Old 08-03-2009, 04:10 AM
Cute and cuddly boys!
mazdaparts's Avatar
Send a message via Yahoo to mazdaparts
When was this published? "Not charge air cooled"? Pre '99?
2002 F250 Crewcab Shortbed 4X4 Totaled 6/16/12
2000 Expedition Eddie Bauer 4x4
There are 2 rules to getting ahead.
Rule #1. Don't tell anyone everything you know.
mazdaparts is offline
post #7 of 17 (permalink) Old 08-03-2009, 04:35 AM
"Not Exhaust Brake Compatible" ??!?
madpogue is offline
post #8 of 17 (permalink) Old 08-03-2009, 06:13 AM
Since the ad indicated 210 HP, I'm assuming it was a 1996 or 1997 ad. Those years didn't have intercoolers (or CAC as they seem to like to call it).
Also, there was some concern over how much backpressure could be supported on the 7.3L and whether or not an exhaust brake was practical because it could technically lift the exhaust valves on decel from a high RPM.
What they fail to tell you in the ad is the the ISB suffered from the exact same problem. In fact, most exhaust brake kits installed on the ISB will tell you to replace the exhaust valve spring with heavier springs to prevent a valve collision.
Other than that, Cummins is pretty well on target in the ad. The blocks ARE stronger, the bearing journals are larger with more surface area and the rods are huge compared to the 7.3L. Also, an inline six will make more torque than a V8 of the same displacement because of the crank angles between each combustion event.
Still a neat ad. Now to find a retort from Ford!
post #9 of 17 (permalink) Old 08-03-2009, 09:04 PM
97 OBS PSD
Aaron Ford's Avatar
I know, I know and my Johnson is likely smaller than all those fellers in the pecker miracle ads, but I am okay with it...
My supervisor is doing a Ford Cummins swap. He must be insecure about something...
J/K
Cool article, thanks for posting.
Aaron
97 PSD 4X4 250K, Ron Holland/Banks 1.00 A/R, EBPV Delete, 3" DP, Kitty Delete, PHP Phoenix 6 POS, 140V IDM, Autometers on the Pillar,4" Intake, 17 degree SD pump, 18-20 psi depending on setting...
Aaron Ford is offline
post #10 of 17 (permalink) Old 08-03-2009, 10:11 PM
I Can't deny the that when my Powerstoke blows, I will be doing a cummins swap
if I could have bought my 96 with a factory cummins I would have, But its the Dodge trucks that I Dislike so much..
no doubt they're built stronger, And you tend to see alot better MPG in my experience
but I'm still rockin the IH!
96'
F250 Some stuff
Bamboo is offline
