Stumbles pops and white smoke - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 08-02-2009, 06:18 AM Thread Starter
Truck is a 97 F-250 with 175000 miles on it. It puffs a little white smoke at start up, but then it clears up within a few minutes. It smells like it is running real rich to me.
If you rev it in neutral, it comes right up to about 2500 rpm with no problem, but if you floor it from there, all hell breaks loose. It starts sputtering and popping like a gas motor does when it is out of time.
I am thinking it may be injectors, but I am curious if anyone else has had this problem, and if so, what was the cause.
I ran AE on it, and no codes, no check engine light.
Cylinder contribution passed with no faults
Buzz test passed but the solenoids sounded real weak to me compared to ones I have heard in the past.
Anyway, sorry for the long post, just looking for ideas.
Any advice is appreciated
broncoguy is offline
post #2 of 5 (permalink) Old 08-02-2009, 05:47 PM
Re: Stumbles pops and white smoke
the white smoke at start up is normal, thats raw fuel. as for the others problems im unsure so someone else should be along to chime in.
02 f250
countryboyrob is offline
post #3 of 5 (permalink) Old 08-02-2009, 06:51 PM
stroker for life
longlivepowerstrokes's Avatar
i would say injectors. mine are shot. its runs ok until i gets past 2500 rpm then it just runs like poop
95 PSD, 5 speed manual,
ts 6 position chip,S&B intake,
6" mitre stack
Not fast and will never be fast
longlivepowerstrokes is offline
post #4 of 5 (permalink) Old 08-02-2009, 10:20 PM
What else?
smokyred's Avatar
Check your fuel pressure first.
Dave
smokyred is offline
post #5 of 5 (permalink) Old 08-06-2009, 01:36 AM
Gone Broke
Stroker96's Avatar
its true, i see it almost everyday. dont let it get as bad as his truck. it makes me wanna cry seein it start a run
08 F-350 CC SB King Ranch 4x4
H&S Black Maxx 300 tune, Unlimited Intake, 6" Exhaust, Fuel Nutz wrapped with 295 Trail Grappler's
2000 F350 6spd Powerstroke For Sale!
UNLIMITED DIESEL PERFORMANCE
Stroker96 is offline
