Vacuum pump squeak toy - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 08-02-2009, 03:57 AM Thread Starter
'95 PSD 5-speed 4x4 ext cab, 64,000-ish miles. Yes, I did a search.
The vacuum pum squeaks like a doggy squeak toy, aprx once per revolution of the pulley. It sounds more like an internal squeak, like a diaphragm inside the pump or something, rather than simply a shaft bearing noise.
Not seeing any pump oil on the outside. It also sucks big time ... I mean, it doesn't suck ... I mean, it produces plenty of vacuum. No idea if it's OEM or aftermarket; it has a sticker with some brand name I don't remember, and "Made in Hungary".
Ideas?
madpogue is offline
post #2 of 16 (permalink) Old 08-04-2009, 02:11 AM
Re: Vacuum pump squeak toy
R u sure the noise isnt comming from the power steering pump just below the vacuum pump? Does the noise go away after you have been driving for 10 mins?
1995 Reg Cab 2wd LB--Baby Swamps/SBC Con OFE/Ts 6pos/ Swamps tunes/ Intake/ Exhaust/ No lift on 35's
4runner buggy, on 4d's, chevy 4.3 cpi/4l60e, 5.71's, Doubler with 4.7 rear case, linked rear, longs...etc
Scottapher is offline
post #3 of 16 (permalink) Old 08-04-2009, 02:47 AM
<---Best intake plenums
powertrip's Avatar
i have the same squeak from my pump. been like that for some time now.
RDRCM #29
"New opinions are always suspected, and usually opposed,without any other reason but because they are not already common" John Locke
powertrip is offline
post #4 of 16 (permalink) Old 08-04-2009, 02:51 AM
Harl
Harl's Avatar
Send a message via AIM to Harl
Yep.. When we had the motor out of my dads 97 if you took it and turned it by hand and it made a squeak but when its running at normal speed its fine..
Cody,17
DD-1996 F250 Powerstroke, 5speed, 4x4 ecsb
Mods: GlowShift Gauges-Boost, Pryo, Oil psi and Fuel psi. DIY 6637 Intake, 160/100's, Wildman 6pos, Stage 2 water/meth, D66, TE HPOP, Vailer Clutch, Custom Bars and 5in turbo back....
PT-1995 F350- totaled
Soon to be brought back to a 1992
Harl is offline
post #5 of 16 (permalink) Old 08-04-2009, 04:27 AM Thread Starter
I removed the belt and spun each pulley by hand. The vac pump was the only one that had a voice.
Well, something was squeaking with the engine running as well. Serp belt is way past its bedtime; I think it's the original (Ford Part # is barely visible), but the noise sounded more like a component squeak than a belt squeal. I suppose I could put a fresh belt on first and try it. Shoot, I could pull the belt off the other truck, I suppose.
So is this for real: Ford Vacuum Pump - 7.3 L ? It's a wicked good price; just a few dollars more than some iffy reman, and they claim it's OEM. And with no core, we'd have a spare. Reputable enterprise? Too good to be true?
madpogue is offline
post #6 of 16 (permalink) Old 08-04-2009, 04:34 PM
<----Simply the best.
StrokerTurbo7.3's Avatar
Send a message via AIM to StrokerTurbo7.3
Mine squeeked when it went bad. Are the brakes tough to apply?
No longer a proud member of PSN.
StrokerTurbo7.3 is offline
post #7 of 16 (permalink) Old 08-04-2009, 09:15 PM Thread Starter
No, like I said, vacuum is right up there. HVAC controls work fine. Still, I think we're set on replacement; at least with that accuratediesel one, we'll have a spare. Still wondering if they're legit/reputable.
madpogue is offline
post #8 of 16 (permalink) Old 08-07-2009, 08:21 PM
THE ONE AND ONLY!
Big K's Avatar
Send a message via AIM to Big K Send a message via MSN to Big K Send a message via Yahoo to Big K
Ideas?
Be ready to REPLACE it....it will FAIL VERY SOON.....
Kevin "Big K" Neal
President and Webmaster
North Texas Power Stroke Association
972-768-7252
Big K is offline
post #9 of 16 (permalink) Old 08-07-2009, 09:10 PM
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
the little round button on mine rattles. god i hate that thing. any fixes?
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
post #10 of 16 (permalink) Old 08-07-2009, 10:09 PM
mandkole's Avatar
when it fails it will be swift, messy and leave you stranded
2000 F250 CCSB-- GT4294R, 250/100s, Dahl/Fuelab, PHP, scan gauge, stock 17* pump
1994 F250 4x4 SC (sold)
1997 F250 CCSB 2wd (sold)
mandkole is offline
