Brake booster - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 08-02-2009, 02:57 AM Thread Starter
Brake booster
Do I have to bleed the brakes when I replace the booster?
1997 F-250 PSD, 130k, 4x4, Outlaw E4ODX, Standard Cab, reg bed, 3.55 LS rear, Swamps 225/146 injectors, Autometer Guages Pyro/Boost/Tranny, 3" downpipe, 3.5" adjusted exhaust, ts 6 pos chip, Tonys fun programs, Tru-Cool H7B, 285/75, factory alum rims, Western V-Plow, 6.0 intercooler installed not plumbed
BlindViper is offline
post #2 of 11 (permalink) Old 08-02-2009, 03:19 AM
original "REZNECK"
kbnord's Avatar
Re: Brake booster
shouldnt booster is higher than your brakes
twice tottalled
01 F250 cc 4x4 straight pipe, custom front and rear bumpers, 1 ton rear susp, flatbed, TS Chip, king ranch rims, 315 tires
Originally Posted by Aljay
Since when do 7.3's puke coolant like an overfilled hooker on a busy night ?
kbnord is offline
post #3 of 11 (permalink) Old 08-02-2009, 03:21 AM
Re: Brake booster
No. As long as you have not broke the brake lines lose.
Rodknocker is offline
post #4 of 11 (permalink) Old 08-02-2009, 03:24 AM
original "REZNECK"
kbnord's Avatar
Re: Brake booster
why are you changing the booster? you might want to consider changing all the fluid if its contaminated
twice tottalled
kbnord is offline
post #5 of 11 (permalink) Old 08-02-2009, 04:05 AM
Don't EFN worry about it
Aljay's Avatar
Re: Brake booster
Unbolt the master and pull it forward and then R&R the booster thats the way I have done it in the past.
Tuned by T Wildman
Aljay is offline
post #6 of 11 (permalink) Old 08-02-2009, 05:06 AM Thread Starter
Re: Brake booster
My brake pedal keeps getting hard to push, and the "brake" light comes on in the dash. It does it intermittently the vacuum pump has good vacuum. I have no problem bleeding the brakes but I wanted to make sure if I needed a 2nd person is all.
post #7 of 11 (permalink) Old 08-02-2009, 05:08 AM
Aljay's Avatar
Re: Brake booster
Shouln't need another person unless its for bringing beers or handing tools to you.
Tuned by T Wildman
Aljay is offline
post #8 of 11 (permalink) Old 08-03-2009, 08:51 PM Thread Starter
Re: Brake booster
So i just replaced the booster and the damn brake light still comes on randomly. When the light comes on the brakes get hard to push. Guess its time for a vacuum pump.....right?
post #9 of 11 (permalink) Old 08-04-2009, 01:52 AM
What else?
smokyred's Avatar
Re: Brake booster
What was the vacuum reading when you say the pump has "good" vacuum? The spec is 18"-21" IIRC.
Dave
smokyred is offline
post #10 of 11 (permalink) Old 08-04-2009, 03:33 AM Thread Starter
Re: Brake booster
I am gonna have to run a gauge into the truck and check because the problem is intermittent.
