OBS SUSPENSION - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 07-31-2009, 10:27 PM Thread Starter
OBS SUSPENSION
i have a dana 60 front end with stock f250 leafs and one helper leaf. i hate the ride, thinking about doing bronco coil buckets and 79 bronco raidius arms. is this doable ?
cp3504x4 is offline
post #2 of 15 (permalink) Old 07-31-2009, 11:22 PM
Re: OBS SUSPENSION
hopefully obs wiz will chime in, he is THE expert on obs suspensions. i think i read somewhere he is riding on an 08 suspension on his truck.
02 f250
countryboyrob is offline
post #3 of 15 (permalink) Old 07-31-2009, 11:28 PM
The Original
BigStroker's Avatar
Re: OBS SUSPENSION
Man the easiest thing would be RSK kit and SuperDuty Springs
[CENTER]1994 F350 4x4 5spd, 1995 F250 4x4 5spd, 1996 F250 4x2 auto, 1997 F350 4x4 auto, 1997 F250 4x2 auto
#27
BigStroker is offline
post #4 of 15 (permalink) Old 08-01-2009, 12:21 AM Thread Starter
Re: OBS SUSPENSION
rsk will not work with a western utrimount plow set up, thats why i would like to try this. obs wiz has an 08 sd suspension on his obs, but i can not find an 05 to 09 full suspension set up, can you?
cp3504x4 is offline
post #5 of 15 (permalink) Old 08-01-2009, 12:37 AM
Re: OBS SUSPENSION
Please dont waste your money on pulling these items from a donor truck. You can easily build your own suspension setup using brackets and suspensions joints/etc from places like ballistic fabrication and blue torch fabworks
If you have any basic mechanical skill, building your own suspension using a radius arm 3 link/ 5 link/ or double or single triangulated 4 link, will be just as easy as taking items off of another truck and putting them on yours. Plus you will be much happier putting your needs into your design than "modifying" your truck using "oem" equipment.
1995 Reg Cab 2wd LB--Baby Swamps/SBC Con OFE/Ts 6pos/ Swamps tunes/ Intake/ Exhaust/ No lift on 35's
4runner buggy, on 4d's, chevy 4.3 cpi/4l60e, 5.71's, Doubler with 4.7 rear case, linked rear, longs...etc
Scottapher is offline
post #6 of 15 (permalink) Old 08-02-2009, 04:00 AM
96P_Stroke4x4's Avatar
Re: OBS SUSPENSION
fwiw, if you want to soften the ride a little without the rsk, put stock f-350 springs under the front. f-250 springs will ride worse with a dana 60, especially with helper springs.
'96 F-250 XLT,x-cab,4x4,BTS,363k,dana60,Swamps175/173s,Dieselsite Adrenaline HPOP,CPR Fuel system,rear discs,4" dp to 6" exhaust,twin 6" stacks,Tymar, Boost Pyro Tranny and white-faced gauges,I/C,onboard air,HX mod,TW 6-position chip
96P_Stroke4x4 is offline
post #7 of 15 (permalink) Old 08-02-2009, 04:13 AM
OBS junkie
Cat_Rebel's Avatar
Re: OBS SUSPENSION
What you don't like the pogo stick feeling?
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #8 of 15 (permalink) Old 08-02-2009, 03:40 PM Thread Starter
Re: OBS SUSPENSION
it is not like a pogo stick more like a cat d3 dozer. the front end has zero flex.
cp3504x4 is offline
post #9 of 15 (permalink) Old 08-02-2009, 03:51 PM
Re: OBS SUSPENSION
cp350.....hahaaa..thats funny I will add in a field of bolders with the D3 dozer hahahaaa
FWIW.....
Had the same suspension...stock IFS with extra leaf and F450 springs in the rear when I got it...mmm rode choppy and too stiff for my liking.....switched to OBS front and rear with Velvet rides, front and rear anti-sways. Put poly bushings in everything but the rear springs. It now handles like and rides awesome....
Why can't it fit the springs with plow mount??
jrc
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
post #10 of 15 (permalink) Old 08-02-2009, 03:58 PM
sick97psd1's Avatar
Send a message via AIM to sick97psd1
Re: OBS SUSPENSION
I have also looked into do the RSK kit on mine but the way the plow mount is attatched to the frame of the truck it just isn't possible.
sick97psd1 is offline
