No Start Grrr... SOLVED - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 1 (permalink) Old 07-30-2009, 06:02 AM Thread Starter
97 OBS PSD
Aaron Ford's Avatar
It was the HPOP. I found a new IPR and HPOP at a local junkyard (Jordans). Paid $50 for the IPR and $250 for the pump. The pump is a 17 degree with a 2006 build date. My old one had a casting date of 1998. Installation was easy and required no new gaskets or o-rings. Sealed right up. Runs like a champ. Haven't seen the performance side, but I also have stock injectors. Gonna put a load behind it and see what it will pull.
Aaron
97 PSD 4X4 250K, Ron Holland/Banks 1.00 A/R, EBPV Delete, 3" DP, Kitty Delete, PHP Phoenix 6 POS, 140V IDM, Autometers on the Pillar,4" Intake, 17 degree SD pump, 18-20 psi depending on setting...
Aaron Ford is offline
