Lets talk rear ends.. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 37 (permalink) Old 07-27-2009, 11:47 PM Thread Starter
The Original
BigStroker's Avatar
I should know this but I don't
What is the difference in the Dually vs the Single rear end?
[CENTER]1994 F350 4x4 5spd, 1995 F250 4x4 5spd, 1996 F250 4x2 auto, 1997 F350 4x4 auto, 1997 F250 4x2 auto
#27
BigStroker is offline
post #2 of 37 (permalink) Old 07-27-2009, 11:52 PM
Young'n
powerstrokeracing's Avatar
Re: Lets talk rear ends..
well the single has 1 tire on each side, and a dually has 2 tires on each side!
Jk id like to know this too
powerstrokeracing is offline
post #3 of 37 (permalink) Old 07-28-2009, 12:06 AM
Hater Club
Dirk's Avatar
OBS SRW: Sterling 10.25 - These came in 3.55 (most popular) and 4.10
SD SRW: Sterling 10.5 - These came is 3.73 (most popular) and 4.10
Dually will use the Dana 80, unless it's a F550. And it uses the Dana 130 I believe.
F350 had 3.73, 4.10 or 4.30
F450 COULD have 4.10, but generally was 4.30
F550 generally had 4.30, but there are a few 4.56's running around.
Porch Monkey. It's cool, I'm taking it back.
Dirk is offline
post #4 of 37 (permalink) Old 07-28-2009, 12:07 AM
Busy Busy
Marty's Avatar
Dana 110 I thought but I've been wrong... a lot... lol
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #5 of 37 (permalink) Old 07-28-2009, 12:17 AM
Hater Club
Dirk's Avatar
Go jump under a f550. Looks like a damn dump truck axle.
Dirk is offline
post #6 of 37 (permalink) Old 07-28-2009, 12:21 AM Thread Starter
The Original
BigStroker's Avatar
Dirk,
The OBS dually rear is a Dana 80? I thought it was a 10.25 with longer studs or something....hmmmmm
#27
post #7 of 37 (permalink) Old 07-28-2009, 12:38 AM
Hater Club
Dirk's Avatar
Originally Posted by BigStroker View Post
Dirk,
That is a GREAT question...
My friend's 1997 had a dana 80. Found this out the hard way when a bearing failed. Autozone and Napa kept giving him sterling parts that didn't work. He bought the truck new, never had any other rear axle work done. I just spoke with JJ.. and his 1995 f350 DRW may have a 10.25, he will check.
Dirk is offline
post #8 of 37 (permalink) Old 07-28-2009, 12:43 AM
WWDD
Dzchey21's Avatar
Thats no sh!t looks like it should be a fockin two speed rearend.
I worked for a napa for several years, on superduties you could always ask if it had duals or single rear wheel to figure it out, but the obs trucks were hit and miss, some of the later trucks were dana 80's but some of the early ones were 10.25
couple trucks one fast one not
Dzchey21 is offline
post #9 of 37 (permalink) Old 07-28-2009, 12:50 AM
Super Hauler!
Super_Hauler's Avatar
My 450 sd has a 110 with 4.88. 550 is the same other than the axel tube is square tube instead of pipe.
Super_Hauler is offline
post #10 of 37 (permalink) Old 07-28-2009, 12:59 AM
Hater Club
Dirk's Avatar
JJ will pull the tag off the F550 and I'll post it.
Dirk is offline
