zf-5 Rebuild kits - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 07-27-2009, 06:52 AM Thread Starter
PSD
CNDiesel's Avatar
zf-5 Rebuild kits
Where is a good place to find parts for my zf5...
Mine packed it in today.
1996 crew cab long box. 3.73s, auto 493/1135 stockish auto trans.
CNDiesel is offline
post #2 of 15 (permalink) Old 07-27-2009, 02:07 PM
Smarty Power!
John_DeereGreen's Avatar
Send a message via AIM to John_DeereGreen Send a message via Yahoo to John_DeereGreen
Re: zf-5 Rebuild kits
Probably cheaper to either put a junkyard trans in, or convert to an auto.
What exactly happened?
Jarrett Matthew
04.5 QCSB auto common rail
Smarty TnT; ISSPRO PERFORMAX
Suncoast full billet
John_DeereGreen is offline
post #3 of 15 (permalink) Old 07-28-2009, 07:17 AM Thread Starter
PSD
CNDiesel's Avatar
Reverse gave out while driving... started grinding when the truck wasnt under load...Driving on a level hill and take off the gas for a few seconds and it would grind like a grinder.
Evenchually It ended up that you could put the shifter in the spot with the truck idling with no clutch and nothing would happen.
CNDiesel is offline
post #4 of 15 (permalink) Old 07-29-2009, 02:20 PM
Smarty Power!
Been speed shifting much?
Jarrett Matthew
post #5 of 15 (permalink) Old 07-29-2009, 10:15 PM
FordBoy86's Avatar
If you don't get the clutch all the way in when you are trying to shift in reverse, even just a little grinding, over time will cause that gear to go. Happens quite a bit. Just rebuilt one this past winter cause the grinding was so loud in neutral you couldn't even hear the engine running.
FordBoy86 is offline
post #6 of 15 (permalink) Old 08-01-2009, 02:25 AM
obs stroker's Avatar
thats weird because i shift sometimes without the clutch...and it doesnt grind most of the time but when i dont catch it right it does!
FORD STOPPED MAKING TRUCKS ON 7/31/09!
1994 f-250 7.3 turbo diesel, intake, chip, 33's, 5 spd.
1994 f-150 good ol 300 six chipped and intake TB spacer, 5spd.
obs stroker is offline
post #7 of 15 (permalink) Old 08-07-2009, 08:24 PM
Call Dan at Midwest Trans 507-824-2012
TECH51 is offline
post #8 of 15 (permalink) Old 08-08-2009, 12:49 AM
PSN nerd
let a shop do a rebuild there are quite a few specialty tools and jigs needed
but if you got the hp coming on like me i am swappin to an auto
97 F250SC 4X4 4 LINKED ON AIR <- FOR SALE!!!!!!
00 F350CC 4x4 I NEED A FLATBED FOR IT!!!!! LET ME KNOW IF YALL KNOW ANYBODY THAT HAS ONE
JAKE is offline
post #9 of 15 (permalink) Old 08-08-2009, 12:58 AM
cntryboy17's Avatar
I do the same just used to driving our semi
E99 F-350 CCSB 4x4
1990 F250 7.3idi 4x4 5 speed- SOLD!
cntryboy17 is offline
post #10 of 15 (permalink) Old 08-14-2009, 09:13 AM Thread Starter
PSD
CNDiesel's Avatar
Yeah I ended up buying a new one online. Its in the mail. should be here in under a week.
But I am going to be swapping this new 5spd for a guy with a auto.
CNDiesel is offline
