HPOP ID 646056A - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 07-26-2009, 08:54 PM Thread Starter
97 OBS PSD
Aaron Ford's Avatar
HPOP ID 646056A
I am trying to ID my High Pressure Oil Pump. I do not think it is factory due to finding parts of what looked to be an old HPOP in the engine valley (ball bearings/o-rings) and the fact that the HPOP is newer/cleaner than anything else in my driveway. It is a flat backed pump that has the markings 646056A on a UPC sticker and also embossed into the pump casting above the sticker.
It it a 15, 17, Ford reman, Autozone special? It looks considerably newer than the IPR sticking in the back of it...
Thanks in Advance,
Aaron
97 PSD 4X4 250K, Ron Holland/Banks 1.00 A/R, EBPV Delete, 3" DP, Kitty Delete, PHP Phoenix 6 POS, 140V IDM, Autometers on the Pillar,4" Intake, 17 degree SD pump, 18-20 psi depending on setting...
Aaron Ford is offline
post #2 of 4 (permalink) Old 07-26-2009, 08:59 PM
Re: HPOP ID 646056A
IIRC the only way to tell what pump it is, is by taking it apart. but im not sure i know i read it on here a while back.
02 f250
countryboyrob is offline
post #3 of 4 (permalink) Old 08-02-2009, 05:05 PM
Cratos's Avatar
Re: HPOP ID 646056A
take the snap ring and cover off the back if it has a bushing it is the 17 if a bearing it is a 15
Blue 2012 XLT SCLB 4X4 , 38,550 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter.
Cratos is offline
post #4 of 4 (permalink) Old 08-04-2009, 08:18 PM Thread Starter
97 OBS PSD
Aaron Ford's Avatar
Re: HPOP ID 646056A
Thanks Cratos. It turned out that the HPOP was dead so it was swapped with a true 17 degree unit. The 646056 was a reman but with a build date of 1998. The new pump has a build date of 2006 and a humped rear cover. I was thinking about taking it apart but was curious if it would reduce its value as a core.
Truck runs like a scalded dog.
Aaron
