Gas mileage question. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 07-26-2009, 04:15 PM Thread Starter
I was wonderin what you guys are gettin per tank as far as total miles? How many gallons does each tank hold?
1995 2wd Powerstroke 7.3L 5spd
Cat delete/3 inch DP/1.0 Turbo w/ Non-EBPV
TS 6 position chip
Single mass flywheel conversion
DIY air intake
MoStrokinIt is offline
post #2 of 7 (permalink) Old 07-26-2009, 04:43 PM
Re: Gas mileage question.
19 gallons each. Total miles per tank depends on whether I'm towing, or if empty, depends how I'm driving it. I have gotten well over 300 miles out of one tank, IIRC, when driving the speed limit....
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air, Beans tunes on VA 4 position chip, Adrenaline HPOP, VDO boost/pyro/outside temp gauges, Ford digital AIC, DPPI downpipe, gutted EBPV, modded turbo ped, Con OFE, add-a-leafs front/rear, Monroe Reflex shocks, Milemarker 449SS hubs...coming soon: 6.0 IC...wish list: Stage 2's
nashvillebill is offline
post #3 of 7 (permalink) Old 07-26-2009, 04:52 PM
Bugman's Avatar
On my long box truck I have gotten a little bit less than 22 gallons into the front tank and 19 in the rear. My millage won't help you since I am usually loaded when I am driving and really care abut the millage along with having a 4:10 rear end and being a 4x4. But you really need to figure it out using the miles driven divided by the gallons used to get an accurate millage figure.
Bugman is offline
post #4 of 7 (permalink) Old 07-26-2009, 05:05 PM Thread Starter
Ok thanks guys..I may get 250 out of a tank with normal drivin, just seems low to me.
TS 6 position chip
DIY air intake
post #5 of 7 (permalink) Old 07-26-2009, 05:25 PM
Senior Veteran Member
Centxdiesel's Avatar
Garage
Before tunes, I got 250 on front tank in town driving and 25 mile commute to and from work. On a recent trip to San Antonio carrying a bed for my daughter attending college there and staying at 55 mph for fear it may blow out (king size) i was able to get right at 200 miles on half of rear tank. that averaged to about 22 mpg on the trip. I had cruise on and ran 55 the whole way and back. The other half of that tank was gone after another 100 miles of driving back here going to and from to work. .
Centxdiesel
1997 F250 XL SC, 512HP 1019TQ,
30% nozzle Hybrids from [email protected]
Adrenaline, Beans D-66,Beans E-Fuel,Valair Ceramic-Kevlar clutch.
Awesome Tuning by: Matt: from:
Centxdiesel is offline
post #6 of 7 (permalink) Old 07-26-2009, 06:17 PM
Bugman's Avatar
You really can't go on the half tank theory for fuel mileage. On my truck the rear tank comes off of full in a hurry but will go for a long time on empty and then I can still only put in 15 gallons leaving me 3-4 gallons left in the tank witch has been on empty for quite a while. The front tank will run a long ways on full but when it hits the "E" it is empty.
Bugman is offline
post #7 of 7 (permalink) Old 07-26-2009, 06:30 PM
snow cowboy
jpzjr32's Avatar
Send a message via AIM to jpzjr32
i thinks its a 28 gallon tank but not sure and depending on how i drive and how much weight is on my trailer ova 350 miles per tank
2006 f350
crew cab 6' bed
sct sf3 tuner w/custom tunes
4inch turbo back straight pipe (6 inch stacks)
cold air intake
arp headstuds
intake mamifold with intake pipe
painless turbo timer
fuel system
175 cc injectors
all thanks to Ken at KT Performance
and many more physical mods
jpzjr32 is offline
