truck sputter - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 07-24-2009, 03:43 AM Thread Starter
Offical Puddle Displacer
pstroke96's Avatar
Send a message via AIM to pstroke96
truck sputter
this is a littly lenghty to explain but, when i was going down the road at a constant speed the truck jerked a little like it lost power or missed but it only did it once and it was very breif. it felt like a transmission thing but later on it did the same thing again and i was paying attention, and the tach dropped a bit probably like 200 rpms then came right back up like nothing happened. i drove the truck for over an hour after and it never did it again. could it just have been a piece of dirt or something that clogged up then blew through or could it be more than that?
thanks
pstroke96 is offline
post #2 of 12 (permalink) Old 07-24-2009, 12:57 PM
Senior Veteran Member
Centxdiesel's Avatar
Garage
Re: truck sputter
Possible CPS. Have you changed yours ever? Ever had the recall done on them? Just my $.02.
Centxdiesel
1997 F250 XL SC, 512HP 1019TQ,
30% nozzle Hybrids from [email protected]
Adrenaline, Beans D-66,Beans E-Fuel,Valair Ceramic-Kevlar clutch.
Awesome Tuning by: Matt: from:
Centxdiesel is offline
post #3 of 12 (permalink) Old 07-24-2009, 01:10 PM
Re: truck sputter
Sounds like the same symptoms when my CPS started going.
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air, Beans tunes on VA 4 position chip, Adrenaline HPOP, VDO boost/pyro/outside temp gauges, Ford digital AIC, DPPI downpipe, gutted EBPV, modded turbo ped, Con OFE, add-a-leafs front/rear, Monroe Reflex shocks, Milemarker 449SS hubs...coming soon: 6.0 IC...wish list: Stage 2's
nashvillebill is offline
post #4 of 12 (permalink) Old 07-24-2009, 05:06 PM Thread Starter
pstroke96's Avatar
Re: truck sputter
i dont know. i havn't but ive only had the truck 2 months if it was recalled the former owner might have. it has the replacement airbox that replaced th recalled one. os he did take it in. it might have deen done. how can i check it?
Last edited by pstroke96; 07-24-2009 at 05:08 PM. Reason: wrote the same thing twice
post #5 of 12 (permalink) Old 07-24-2009, 06:29 PM
Re: truck sputter
It'd throw a code, if you have access to a scantool that works on ours.
post #6 of 12 (permalink) Old 07-24-2009, 06:43 PM
oil burner
tughill283's Avatar
Re: truck sputter
sounds kinda like what im experiencing,it does at low throttle/low load.
tughill283 is offline
post #7 of 12 (permalink) Old 07-25-2009, 12:52 AM Thread Starter
pstroke96's Avatar
Re: truck sputter
yeah around 1000-1300 rpm and while empty it did it
post #8 of 12 (permalink) Old 07-25-2009, 04:47 AM
oil burner
tughill283's Avatar
Re: truck sputter
yup, i just got my truck so will see if it gets worse,i dont want to be posting in 911 section though
post #9 of 12 (permalink) Old 07-25-2009, 05:42 PM Thread Starter
pstroke96's Avatar
Re: truck sputter
me either but it starts right up and runs like a top other than that. also ive gone almost 250 miles since and it hasnt done it again
post #10 of 12 (permalink) Old 07-25-2009, 06:01 PM
The Original
BigStroker's Avatar
Re: truck sputter
Bet its the CPS they cost $20-25 at Ford cheap insurance to just replace it. If that doesn't do it then you have a replacement in the glovebox incase for later
[CENTER]1994 F350 4x4 5spd, 1995 F250 4x4 5spd, 1996 F250 4x2 auto, 1997 F350 4x4 auto, 1997 F250 4x2 auto
#27
BigStroker is offline
