Exhaust manifold gaskets? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 07-24-2009, 12:36 AM Thread Starter
First off you guys are all awesome! Now another question, from the factory there is no manifold gasket, but I foud a PN for one. Do I need these?
P.S. if I start ticking anyone off with too many questions let me know and I'll back off, I've been hittin ya'll up for alot lately, but hopefully when I get this mother done I can contribute some too.
ctoney063 is offline
post #2 of 8 (permalink) Old 07-24-2009, 01:36 AM
Terminator Nation
Re: Exhaust manifold gaskets?
The factory gasket is a steel embossed one. Use them if your mating surfaces are slightly irregular.
old man dave is offline
post #3 of 8 (permalink) Old 07-25-2009, 02:54 AM
What else?
smokyred's Avatar
I used them because they were inexpensive and I didn't feel like pulling the manifolds back off if I did have a leak.
Question away, if we get tired of them, we won't answer, lol. You've got a long way to go before you'll ever be an Andrew!
Dave
smokyred is offline
post #4 of 8 (permalink) Old 07-27-2009, 08:24 AM
F350 FF's Avatar
Whats the part num on those gaskets? My exhaust manifold gaskets are leaking so those are gonna be replaced when i get home along with a bunch of stuff. Thanks for the let know.
matt z
Have - 95' F350 PSD, 2WD supercab dually, E4OD, 4:10's, Tymar intake, 3" DP, Bully Dog 4" cat back, CPR fuel bowl delete / E-Fuel, Adrenaline Oil
Want - ZF5, Flatbed
F350 FF is offline
post #5 of 8 (permalink) Old 07-27-2009, 03:06 PM
Starting Over
kainers's Avatar
I not 100% if SD gaskets fit an OBS but I got victor reinz part # MS16314 picked them up at napa.There is two in a package I think I paid 40 bucks.
Anytime you remove the manifolds they need to be checked for flatness or what have you.Someone a long time ago they warp when removed.
kainers is offline
post #6 of 8 (permalink) Old 07-27-2009, 04:38 PM
Patrick Feeley's Avatar
Exhaust Manifold Gasket
(Ford) F4TZ-9448-A
(International) 1814219C1
Cheers!
Patrick Feeley is offline
post #7 of 8 (permalink) Old 07-28-2009, 05:00 AM
What else?
smokyred's Avatar
22 bucks or something like that IIRC from Ford.
I stuck mine on the big belt sander at work and cleaned the gasket surface up and trued them up all at once.
Dave
smokyred is offline
post #8 of 8 (permalink) Old 07-28-2009, 03:23 PM
Tater for President!
I'm using the gasket from international...works great and was cheap along with new bolts (seperate part number)...8 bolts plus gasket was right about 50 bucks I believe
#31
1997 F-250 - SCSB - ZF-5, 4x4, 4.10, 17* HPOP, Tymar Intake, TWildman Tunes, SD IC, 4" Straight Exhaust, Dana 60 w/ 3.5" RSK and SD Springs all around on 35" BFG A/Ts - SOLD
2009 - 6.4L - Crew Cab/Long Bed - FX4 - 4" Pure Performance X-Factor Lift - 325/60/20 Duratracs -- FOR SALE
2014 - 6.7L - Crew Cab/Long Bed - Lariat 4x4 - Stock
PSDfreak is offline
