Oil Pan Patch - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 07-23-2009, 02:20 PM Thread Starter
qcfarmer's Avatar
Send a message via Skype™ to qcfarmer
Oil Pan Patch
I have a hole in my oil pan... great. O.K., what are my options really. What happened is when I swapped in the trac bar bracket for my Dana 60 swap, the bolts on the bracket must have been too close. They are about 1/4 inch away from the pan. I guess when the engine torqued last night at the truck pulls, it caused the top bolt to puncture the pan. It's not a major hole but enough so the oil runs out steady. My first thought last night was to just weld the hole shut but it's impossible to get at with a welder. So my options are change the pan (read: pull motor) or maybe try JB Weld? what do you guys think? Thank you
2008 F-450, 6-spd, Spartan DD, Powerstroker67 DPF/CAT delete.
1997 F-250 PSD, SB Ex Cab, 5 spd, Open intake, 3" downpipe, 5" single turnout stack, DIY Stage 1's, T.E. modded HPOP, Tuned by Tony, 4" lift, D60- SOLD
qcfarmer is offline
post #2 of 6 (permalink) Old 07-23-2009, 02:28 PM
<< Hood stack
PSDTECH97's Avatar
Re: Oil Pan Patch
drain the oil, grind or sand the area around the hole and clean the area with some brake clean then use kitty hair figerglass, it comes in a can like bondo and all you do is add the hardener....but you should really just repace the pan
PSDTECH97 is offline
post #3 of 6 (permalink) Old 07-23-2009, 02:41 PM Thread Starter
qcfarmer's Avatar
Re: Oil Pan Patch
I would like to pull the motor but if it's out, there's lots of stuff I would like to do to it and I can't afford to do that just yet... The patch would temporary
qcfarmer is offline
post #4 of 6 (permalink) Old 07-23-2009, 02:45 PM
STILL LEARNING
Bradbilt's Avatar
Re: Oil Pan Patch
Yeah, JB weld or the fiberglass trick, But replacing it would be the correct way
Bradbilt is offline
post #5 of 6 (permalink) Old 07-23-2009, 02:49 PM Thread Starter
qcfarmer's Avatar
Re: Oil Pan Patch
Thanks for all the replies. I'll try to JB wels it and cut those bolts down. There'a another pull next week...
qcfarmer is offline
post #6 of 6 (permalink) Old 07-24-2009, 01:45 AM
Terminator Nation
Re: Oil Pan Patch
Use a piece of sheet metal (tin can?)that covers the hole then JB weld the patch to the pan.
old man dave is offline
