Truck running Hot?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 07-22-2009, 04:12 PM Thread Starter
crittergitters.net
woody_1's Avatar
Truck running Hot??
First, I want to thank eveyone for the help when I thought I blew the motor last time.Brian at BTS my hats off to you. I owe you big for staying on the phone and walking me thru everything.#7 injector and I found my IPR was bad and replaced it.
Now I have another issue.It started over flowing coolant out the fill tank on side of radiator.I started by flushing radiator and changing thermostat. I now still have it pressuring up that fill tank and over flowing.It has not ran hot.It will get warmer than normal ,but not Hot.It use to run around the R on the word normal now around the L.This is on the dummy gauge from factory.
Any Ideas what else to check? I also thought it could be a Head gasket is that possible?
1995 F350,AFE stage 2 ,3" Down pipe,4" Magnaflow Exhaust,custom Shackles,14" and 15" Atlas springs,54"Boggers,20"x14"wheels,2 1/2 ton rockwells w/ 6.72 gears,F-550 Disc brakes,High rise steering,Tranny cooler,Shimmed FPR, gutted EBPV.Autometer gauges.BTS tranny with a PCS trans controller,Stage 2 injectors,Tony's Wildman 6 position chip,Pedal mod.
woody_1 is offline
post #2 of 15 (permalink) Old 07-22-2009, 04:38 PM
Super Hauler!
Super_Hauler's Avatar
Re: Truck running Hot??
well i found my issue last night, it was a clogged radiator, when i say clogged i mean like you couldnt even see through the thing there was so much dust and chit in there. I would check your radiator.
Super_Hauler is offline
post #3 of 15 (permalink) Old 07-22-2009, 04:49 PM Thread Starter
crittergitters.net
woody_1's Avatar
I did flush thru the radiator it seemed pretty clean.I will check it again.
woody_1 is offline
post #4 of 15 (permalink) Old 07-22-2009, 05:13 PM
what thermostat do you have?
02 f250
countryboyrob is offline
post #5 of 15 (permalink) Old 07-22-2009, 06:55 PM Thread Starter
crittergitters.net
woody_1's Avatar
I am pretty sure it was like a 205.It came from Orielly(sp)
woody_1 is offline
post #6 of 15 (permalink) Old 07-23-2009, 01:03 AM
97 OBS PSD
Aaron Ford's Avatar
I have heard that a cracked injector cup can allow fuel to pass into the coolant. Most find oil in their water, not diesel.
Aaron
97 PSD 4X4 250K, Ron Holland/Banks 1.00 A/R, EBPV Delete, 3" DP, Kitty Delete, PHP Phoenix 6 POS, 140V IDM, Autometers on the Pillar,4" Intake, 17 degree SD pump, 18-20 psi depending on setting...
Aaron Ford is offline
post #7 of 15 (permalink) Old 07-23-2009, 11:24 AM Thread Starter
crittergitters.net
woody_1's Avatar
Thanks ,I have not noticed anything in the coolant.
woody_1 is offline
post #8 of 15 (permalink) Old 07-23-2009, 04:00 PM
i think the next lower t-stat is like 189?
02 f250
post #9 of 15 (permalink) Old 07-24-2009, 10:57 PM Thread Starter
crittergitters.net
woody_1's Avatar
Ok I replaced the cap with the same as I had a 16#.When I first started the motor I unscrewed old cap and it had some pressure with a little smoky stuff,but no smell of fuel or oil just antifreeze.Let it run and it did continue to build pressure with same smoky looking stuff???? any ideas??
woody_1 is offline
post #10 of 15 (permalink) Old 07-25-2009, 01:37 AM
Fixing Broken Stuff
toolmangary's Avatar
If you are over flowing out the coolant bottle that is not good, then you must have bubbles through the radiator? if so it is most likely a head gasket
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
