Fan Issues - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 07-22-2009, 06:06 AM Thread Starter
Underfunded
moonshiner's Avatar
Send a message via AIM to moonshiner
Fan Issues
My fan clutch is bad...should I
A) Go direct drive
B) Replace Fan Clutch
C) Go Electric
1996 F350: 4.10's Detroit Locked Front/Rear, Rampage Chip, SD/Racor E-Fuel, Adrenaline, 160cc's, Bell SS/66 Turbo, SD CAC, 315/75/16's Fierce M/Ts, 6" Lift, 6ft Traction Bars, 5" Stacks.
2007 Harley FXSTB: Bassani Prostreet Pipes, Terry Comp tuner, V&H Air Cleaner
2008 Honda Ridgeline RTX
2010 VW Jetta 2.5
SEMPER FI - USMC LT.
moonshiner is offline
post #2 of 5 (permalink) Old 07-22-2009, 12:24 PM
PSN Mega Miler
crowz's Avatar
Re: Fan Issues
Replace the fan clutch.
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
post #3 of 5 (permalink) Old 07-22-2009, 12:32 PM
Senior Veteran Member
Centxdiesel's Avatar
Garage
Re: Fan Issues
Thats what I would do in a heartbeat.
Centxdiesel
1997 F250 XL SC, 512HP 1019TQ,
30% nozzle Hybrids from [email protected]
Adrenaline, Beans D-66,Beans E-Fuel,Valair Ceramic-Kevlar clutch.
Awesome Tuning by: Matt: from:
Centxdiesel is offline
post #4 of 5 (permalink) Old 07-22-2009, 05:36 PM
Re: Fan Issues
Hey Moonshiner,
Would agree to replace the clutch....having said that, depends on what you are doing with your ride. If you tow lots and heavy....stick with stock...if not and want a project then build an E-fan system. I built one that you can pull off in a few minutes and it works well....provided I don't tow my Travel trailer or bigger...6-7k lbs. So for just rippin' around and if you want a project then do it.....I used twin Taurus fans hooked to a thermocoupler with a manual over ride. Have some pix in my truck folder link. Again if you tow best to stick with stock though...
jrc
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
post #5 of 5 (permalink) Old 07-22-2009, 09:10 PM
Question Re: Fan Issues
A) Go direct drive
C) Go Electric
how did you figured out that your fan clutch is bad? What are ways to test it?
F-250 PSD 1996 ext.cab 2WD, Short bed, E4OD.
STROKER #1 is offline
