What gears do I have? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 07-22-2009, 02:09 AM Thread Starter
Early bird gets the worm
95dieselsmoke's Avatar
So I have never known what gears I have in my truck. The tag that is on one of the bolts on the rearend is unreadable. Is there a way to find it on the tag that is on the inside of the drivers door? It Just a bunch of numbers and what not and I dont know what exactly to look for. Need to figure out the gears because I am in the search for a Dana 60 with the same gear ration.
Here is a pic of the tag on the inside of door, I was told I might be able to find out ratio from it. TIA.
95 F250
Dana 60 swap
9" lift/40x13.5x20 ProComps
ZF5 swap/short throw/SouthBend CON OFE
Rosewood stage I's
TW live tuned
SD innercooler
AFE CAI
autometer pyro,boost
6" black miters
95dieselsmoke is offline
post #2 of 11 (permalink) Old 07-22-2009, 02:11 AM
Dairy Mechanic
Magnum PD's Avatar
Re: What gears do I have?
You don't have your old window sticker do you? If not go to your local FORD dealer and give them the VIN and they should tell what it is.
96 Ford F-350 200 cc's, Electric fuel system, TS chip, 17 oil pump, Banks intercooler, 3" intake manifolds, SNOW Water-Meth system, South Bend DxD 3600, Banks brake, 4" stacks. Tuff country ladder bars.
IH RULES Not a 6.0 fan, engine out right now.
Magnum PD is offline
post #3 of 11 (permalink) Old 07-22-2009, 02:20 AM Thread Starter
Thanks, but I got it figured out. 3.55 open spool. For anyone else that is curious...
What is my Ford rear end ratio, do I have positraction - Drivetrain.com
95 F250
Dana 60 swap
Rosewood stage I's
TW live tuned
SD innercooler
AFE CAI
6" black miters
post #4 of 11 (permalink) Old 07-22-2009, 10:41 AM
masterteee89's Avatar
Thats awesome! Thanks for the info. I just checked mine out... C5 = Limited Slip Differential - 4.10.
1997 Ford F-250HD 4x4 SC/LB PSD, 128,000 Miles
MBRP 4inch Straight Pipe w/cat delete and 3inch DP and MBRP 6in Tip
Tymar Intake
Front add-a-leafs w/Skyjacker Nitro 8000 shocks all around.
BFG All Terrains 315/75/16 on Stock Wheels
masterteee89 is offline
post #5 of 11 (permalink) Old 07-22-2009, 04:41 PM
Don't EFN worry about it
Aljay's Avatar
Thats the site I have in my favs.
Tuned by T Wildman
Aljay is offline
post #6 of 11 (permalink) Old 07-30-2009, 12:43 AM
FREE THINKER
Chip's Avatar
Cool ...Thanks man....i got C1 limited slip 3.73's
Chip is offline
post #7 of 11 (permalink) Old 07-30-2009, 01:55 AM
turkey tickler
C-Power's Avatar
man i cant figure mine out......one person told me its the top set of numbers only problem is mine is upside down......the top side(numbers are upside down) would be D1.......but if you fliped it up so you could read the #'s regular it would be C2 i think.... so idk??????
Puller...94 reg cab cummins....lots of fuel and air
Other puller...01 p-pumped custom head jarhead tranny
Tow rig...03 CCSB common rail.
C-Power is offline
post #8 of 11 (permalink) Old 07-30-2009, 02:05 AM
turkey tickler
C-Power's Avatar
ok so i ripped the tag off b/c i got pissed.....now i can read it great....the last 4 digets of the bottom row has to be the ones i want....b.c the top row says S125G.......the last 4 of the bottom say 4D12 so idk mine must be Limited Slip 3.73's??????
C-Power is offline
post #9 of 11 (permalink) Old 07-30-2009, 02:50 AM
powerstrokin95stillsmokin's Avatar
I ALSO HAVE A 95 BUT IT'S A DUALLY,SO HOW'S THAT WORK
95 f-450 regular cab auto trans..14ft flatbed
powerstrokin95stillsmokin is offline
post #10 of 11 (permalink) Old 07-30-2009, 03:26 AM
turkey tickler
C-Power's Avatar
very carefully hahaha.........idk....its pri the same way......i was told judgin from my rpm's that its 4.10's but the tag says 3.73's....so im gonna call the dealer tomorrow........
C-Power is offline
