tranny/clutch noise - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 07-21-2009, 08:19 AM Thread Starter
tranny/clutch noise
my friend put a new one piece flywheel and clutch in his truck and it makes a loud grinding noise when at idle but goes away at about 700-800 rpm. whats wrong? truck is a 94 all stock but exhaust.
cams-76 is offline
post #2 of 3 (permalink) Old 07-22-2009, 01:18 AM
Pulling sled for hire
ParkerFly's Avatar
Re: tranny/clutch noise
That's normal with a one piece flywheel. It will grind a little at idle and at low RPMs, especially when in gear. I know South Bend even puts it in their directions that it will make a grinding noise.
Justin
Justin
#62
'97 F-250 - 255k
463 hp - 7-9-09
BDP/Casserly Stage 2's, Mod H2E, Stealth Stage 2, BDP fuel system, Comp 910s, 7.3 ic, live tuned by Jonathan @ BDP.
ParkerFly is offline
post #3 of 3 (permalink) Old 08-02-2009, 01:39 AM
Yup mine did the same thing and I took it back and asked about it...told it was normal and I would just get used to the sound. I don't like hearing it but what are you to do about it?
1995 2wd Powerstroke 7.3L 5spd
Cat delete/3 inch DP/1.0 Turbo w/ Non-EBPV
TS 6 position chip
Single mass flywheel conversion
DIY air intake
MoStrokinIt is offline
