rearend has oil on it - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 07-19-2009, 03:46 AM Thread Starter
Offical Puddle Displacer
pstroke96's Avatar
Send a message via AIM to pstroke96
my truck has sat alot over the past two months and now that i can drive it around 400 miles since wednesday. the rearend has oil on it. only a little, just enough to make it darker. it is rearend oil. i can smell it. i tried tightening the bolts but i couldnt make them tighter than they already were. any ideas where its coming from or am i just over worried about it?
thanks
pstroke96 is offline
post #2 of 5 (permalink) Old 07-19-2009, 03:57 AM
Re: rearend has oil on it
Hypoid gear oil has a distinct smell, very strong and pungent IMHO.
There's two likely areas to leak: a) the front seal where the driveshaft enters the rear end, and b) the rear cover. There is not a gasket on the rear cover and the thin cheap metal rusts easily. Summit Racing has their brand of rear covers cheaper than most other folks, they have a little more gear oil capacity than stock plus they have a drain plug. And they look nice. Either stock or aftermarket, they seal with a bead of RTV.
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air, Beans tunes on VA 4 position chip, Adrenaline HPOP, VDO boost/pyro/outside temp gauges, Ford digital AIC, DPPI downpipe, gutted EBPV, modded turbo ped, Con OFE, add-a-leafs front/rear, Monroe Reflex shocks, Milemarker 449SS hubs...coming soon: 6.0 IC...wish list: Stage 2's
nashvillebill is offline
post #3 of 5 (permalink) Old 07-19-2009, 07:06 AM
ROLLIN' BLACK!!!!!
blk97power_stroker's Avatar
Send a message via MSN to blk97power_stroker
where on the rear end is the oil. on the cover/bottom. or on the front near the driveshaft. if it is towards the front you may look on the engine or transmission for a leak. it will drip going down the road and splatter on the rearend. my oil pan leaks and covers my rear end.
IF IT DON'T ROLL BLACK.....TAKE IT BACK!!!!!
97 F-350 crew cab 7.3l powerstroke. 250cc/100% hybrid injectors, aig dog fuel, bell turbo s300 turbo(wide open qssb) w/custom built mount & pipes by me, water-meth, ats 5-star trans, intercooler w/tubes built by me, stereo
blk97power_stroker is offline
post #4 of 5 (permalink) Old 07-20-2009, 01:24 AM Thread Starter
pstroke96's Avatar
the oil is on the bottom and the cover. i think its the seal for the cover. when i get a chance im going to take it off and reseal it. thats the cheapest fix so if that doesnt work it ill keep searching
post #5 of 5 (permalink) Old 07-20-2009, 02:47 AM
pjwoolw's Avatar
Use a gasket. Make sure both surfaces are clean and flat. Use Gasgacinch sealer. I've never had a leaky cover. Clean your bolts ad put a little Gasgacinch on them before installation. Torque in a cross pattern to 25 or 30 lbs. Check your breather also. Could be plugged. I use a small fuel filter instead of the vacuum tee on the end. Hope thats it.
Pete in San Ramon
2005 F250 6.0 Lariat 4x4 CC Short bed (stock)
1997 F250 7.3 XLT 4X4 Reg. cab (stock)
1986 F250 6.9 XLT Gone but not forgotten
pjwoolw is offline
