Injector O-ring installation Now No Start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 07-18-2009, 07:20 PM Thread Starter
97 OBS PSD
Aaron Ford's Avatar
I replaced the injector o-rings, the IPR o-rings, and the fuel lines in the engine valley under the filter housing and now it won't start. I have HPOP pressure (500 plus), 50-60 psi fuel, and have kept the batteries on a 10 amp charger and still no response. No smoke from exhaust. Injectors are clicking.
Thanks In Advance,
Aaron
97 PSD 4X4 250K, Ron Holland/Banks 1.00 A/R, EBPV Delete, 3" DP, Kitty Delete, PHP Phoenix 6 POS, 140V IDM, Autometers on the Pillar,4" Intake, 17 degree SD pump, 18-20 psi depending on setting...
Aaron Ford is offline
post #2 of 8 (permalink) Old 07-20-2009, 02:53 AM
Re: Injector O-ring installation Now No Start
Check to see if you are getting fuel to the filter as a start.
1994 F350 Dually w/Powerstroke M.T. 101,000 miles
JDOliver is offline
post #3 of 8 (permalink) Old 07-20-2009, 03:16 AM
On my 2000 you have to fill the oil rail with oil and prime the fuel rails with fuel by beading threm.
2000 F-350 7.3 PSD 4X4 exstended cab 200 K Wicked wheel" open stacks, Banks power elbow, New GP New Injectors
Channing is offline
post #4 of 8 (permalink) Old 07-20-2009, 02:05 PM
blageurt's Avatar
You still have air in the system. Just keep doing what you are doing , bieng carefull not to overheat the starter . Eventually it will start. It just takes a while
blageurt is offline
post #5 of 8 (permalink) Old 07-20-2009, 07:49 PM Thread Starter
97 OBS PSD
Aaron Ford's Avatar
I bled the fuel lines on the back of the heads and got white puffs out of the exhaust. To chicken to crank for too long...
Gonna get back to it this evening,
Aaron
post #6 of 8 (permalink) Old 07-21-2009, 01:56 AM
OEM Moderator
Tom S's Avatar
I would throw a set of jumper cables on there. Sounds to me like she is almost ready to start.
Tom S is offline
post #7 of 8 (permalink) Old 07-21-2009, 02:06 AM
robp823's Avatar
yea your close if ya want check the HPOP resevoir and make sure its full.
robp823 is offline
post #8 of 8 (permalink) Old 07-21-2009, 10:19 PM
shake and bake baby!!
stroked350's Avatar
stand by for a smoke show. sounds like you just gotta keep cranking her.
stroked350 is offline
