VIBRATION - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 07-17-2009, 08:55 PM Thread Starter
VIBRATION
I have a 96 f-550 7.3 powerstroke that has a bad vibration when driving, It has been comming and going but now its getting worse, If you push the clutch in it goes away then comes back when you let the clutch out. Any idea what this may be.
ROADKING is offline
post #2 of 3 (permalink) Old 07-17-2009, 09:24 PM
Re: VIBRATION
My first guess is the dual mass flywheel giving out. Pull the inspection cover and see how much you can rotate the ring gear, more than 5/8 inch means its shot. Bad things (expensive) can happen if the flywheel self-destructs and this is a known failure point.
Cure is a single flywheel with new clutch, do it yourself for less than $1000 (around $750 for a Con O, I think the Valair can be had for around $500)
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air, Beans tunes on VA 4 position chip, Adrenaline HPOP, VDO boost/pyro/outside temp gauges, Ford digital AIC, DPPI downpipe, gutted EBPV, modded turbo ped, Con OFE, add-a-leafs front/rear, Monroe Reflex shocks, Milemarker 449SS hubs...coming soon: 6.0 IC...wish list: Stage 2's
nashvillebill is offline
post #3 of 3 (permalink) Old 07-17-2009, 10:23 PM Thread Starter
Re: VIBRATION
It has been doing this for a year now and when you let it sit and cool down then drive it again the vibration is gone. Then comes back later.
ROADKING is offline
