Decal frontend noise - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 07-17-2009, 04:47 AM Thread Starter
Ok, So got abunch of new stuff in the truck, 6.0 cooler, SD turbo/uppipes etc
And now when deaccelerating, or hitting the brakes I hear kind of like a grinding sound.. Hard to explain as these things usually are
but its only when I lift my foot off the pedal, Or I have to brake semi hard
feels like its more on the drivers side than passenger, But hard to tell
Any advice on where to start looking?, I crawled underthere and can't see much
Thanks..
-patch
96'
F250 Some stuff
Bamboo is offline
post #2 of 5 (permalink) Old 07-17-2009, 05:09 AM
single stacked stroker
yzdude250f's Avatar
Re: Decal frontend noise
maybe the i/c pipes are rubbing or vibrating on something, Did it make the noise before you did the i/c and other things or appear after.
2004 svt focus build # 1041
saving for another truck
97 f-350 SOLD
swamps 175's
2l destroyer 66 turbo
ts with custom tunes
southbend clutch
iss pro gauges
hpx cross over
Traction bars
For as fun as that truck was it was sure a piece of $h!t
Boosting 45psi on a stock charger ^
yzdude250f is offline
post #3 of 5 (permalink) Old 07-17-2009, 05:15 AM Thread Starter
well, we did Intercooler, injectors, Oil pump, Turbo with all the SD stuff
Will check tubes.. It seems strange that its only on decal to me, Being that its kinda rough sounding, Not like downpipe hitting or something like that..
96'
F250 Some stuff
Bamboo is offline
post #4 of 5 (permalink) Old 07-17-2009, 05:49 AM Thread Starter
So, Driver side tube is hitting the hard line AC condenser thing, That goes back along side the firewall towards the passenger side.
Does any body think this kine rubbing could make such noise?
Im having ahard time moving those pipes without loosening the bottom clamp, Which I dont want to do right now..
Thanks for any help..
96'
F250 Some stuff
Bamboo is offline
post #5 of 5 (permalink) Old 07-19-2009, 11:57 PM Thread Starter
Does any body know if you can loosen and move the A/C line coming off the unit?
driver side pipe is hitting that, And I can't move it enough to get it to not rub when I hit the brakes hard, Its driving me NUTS!
96'
F250 Some stuff
Bamboo is offline
