Question about overdrive - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 07-15-2009, 10:18 PM Thread Starter
kurtfromct's Avatar
i read somewhere that driving around town with overdrive ON kills E4ODs. i just wonder how true this is, and if turning overdrive OFF when driving around town does much. thanks
1997 F-350 7.3 POWER STROKE. XLT, 4X4, BLACK, REG CAB, STRAIGHT PIPED, DIAMOND PLATE TOOL BOX AND BED RAILS
SOLD
kurtfromct is offline
post #2 of 5 (permalink) Old 07-16-2009, 07:14 PM
secondarychaos's Avatar
Re: Question about overdrive
I would say that's not true.
first, your transmission won't shift to OD until about 45, so below this, it won't make a single difference. (might be a bit lower if you have 4.10's)
above that, your transmission is set up to downshift before it gets too low in the RPM range, so it should not make a difference there either.
if you're towing something more than, oh, say 5Klbs or so, I would shut it off because i've heard the OD clutches aren't really made for towing. don't know how true this is though...
Dan
96 Powerstroke: 6637, downpipe to dump exhaust, 140v IDM and a shift kit.
84 Honda Sabre V65 1100: pipes, jet kit and new tires. Faster than I think I'll ever need.
secondarychaos is offline
post #3 of 5 (permalink) Old 07-18-2009, 12:53 AM
Fixing Broken Stuff
toolmangary's Avatar
I would also say false, I have had one for over 20 years I'm the original owner and my truck was the first month production E4OD and I have never drove it with the od off. The only thing ever done to my trans has been fluid changes about every 30,000 miles. It has a 4.10 axle also
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #4 of 5 (permalink) Old 07-18-2009, 12:56 AM
<< Hood stack
PSDTECH97's Avatar
i always shut mine off hen i get into the truck just cause i think it is a pain in the a** when it shifts and when i want it to go in....just personal opinion
PSDTECH97 is offline
post #5 of 5 (permalink) Old 07-18-2009, 03:48 PM
tholt34's Avatar
I have heard the e40d and 4r100 in the superdutys are built to tow in overdrive. The only reason you should take it out, is if ur towing at a speed that tranny is shifting in and out of overdrive a lot. That will excessive heat and wear. Thats what i have heard and read before.
2000 F-250 ext cab 4x4 6 spd. Glowshift gauges(egt, boost, and fuel pressure), PHP tuned, DIY intake. MBRP 5 inch straight exhaust with 6 inch tip
tholt34 is offline
