Sd motor in an OBS? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 07-14-2009, 09:05 PM Thread Starter
Sd motor in an OBS?
Hey guys I'm new here and looked for info and couldn't find any. If this has been gone over just point me in the right direction. Here's my problem; I bought a '02 sd 7.3 to put in my '96, just getting started and need any info, problems that have been had and solved, suggestions, ect. I plan on using most of the 02 parts, ie turbo, injectors ect. but am not sure about wirng the thing and downpipe issues. any help is REALLY appreciated
ctoney063 is offline
post #2 of 13 (permalink) Old 07-15-2009, 04:10 AM
OEM Moderator
Tom S's Avatar
Re: Sd motor in an OBS?
Your big snag is that you will not have the ability to mount your obs fuel pump and need to convert to an electric system.
Tom
Tom S is offline
post #3 of 13 (permalink) Old 07-15-2009, 04:15 AM
I make smut cry
Hopefully you got the trans, PCM, and harness......
Cowboy Steve
Powerstroked162 is offline
post #4 of 13 (permalink) Old 07-15-2009, 04:15 AM Thread Starter
well if that's the biggest problem I'm home free right. All that should take is a SD electric unit on the fram right?
post #5 of 13 (permalink) Old 07-15-2009, 04:16 AM
Don't EFN worry about it
Aljay's Avatar
Hope you plan on adding an intercooler . Or building a pipe to connect to the intake.
Tuned by T Wildman
Aljay is offline
post #6 of 13 (permalink) Old 07-15-2009, 04:18 AM Thread Starter
FYI, I got this as a 'core' motor, No. 8 needs sleeved and most of the running gear is there, but no chassis stuff. No PCM,Trans, ect. I'm not sure if the main engine harness is there.
post #7 of 13 (permalink) Old 07-15-2009, 04:18 AM Thread Starter
Yeah, I plan on stock SD intercooler and DIY pipes/mods.
post #8 of 13 (permalink) Old 07-15-2009, 04:20 AM
I make smut cry
No sleevs in a 7.3
You'll need to swap your injectors over to the SD motor. Splits no worky with a OBS
Cowboy Steve
post #9 of 13 (permalink) Old 07-15-2009, 04:21 AM
Aljay's Avatar
Cool it is fairly simple an one of the best mods even if you don't turn the wick up.
PM if you need info on the intercooler deal I have done a few
Tuned by T Wildman
Aljay is offline
post #10 of 13 (permalink) Old 07-15-2009, 05:18 PM Thread Starter
So to give y'all a little more info; I'm running a TS 6 pos chip, gonna do the DP, tho I'm not sure whats involved there. IC from stock SD, gathering parts as I type. I'm getting mixed info on running the AD injectors, some say it'll run fine, others are saying I have to swap over my stock AAs, HELP!! Can I get the pcm reflashed to run ADs if needed? I saw Tom S's turbo upgrade, plan on doin that type of DP, if I can get a good welder. Thanks for all the help.
