Fuel injector wiring harness - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 07-13-2009, 01:45 PM Thread Starter
Post Fuel injector wiring harness
On the weekend I swapped out my injectors; and while cranking the engine with the injector wiring disconnected one connector fell onto the valve cover, went to ground and melted the connector. What are my options to replace the burnt out fuel injector connector;
1. Cut and splice in a used connector from a wreckers
2. Replace the entire upper engine wiring harness
3. Is there a new connector (pigtail) available from someone, local Ford parts guy says not unless you buy the entire engine harness
4. Suggestions???
Thanks
D.T.Starr is offline
post #2 of 6 (permalink) Old 07-13-2009, 02:11 PM
Re: Fuel injector wiring harness
Your dealer's an idiot (surprise). Try here http://store.the-electric-connection...t=products.asp
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air, Beans tunes on VA 4 position chip, Adrenaline HPOP, VDO boost/pyro/outside temp gauges, Ford digital AIC, DPPI downpipe, gutted EBPV, modded turbo ped, Con OFE, add-a-leafs front/rear, Monroe Reflex shocks, Milemarker 449SS hubs...coming soon: 6.0 IC...wish list: Stage 2's
nashvillebill is offline
post #3 of 6 (permalink) Old 07-13-2009, 03:25 PM
Oh, here's another option:
Valve Cover Gasket 7.3L Diesel
post #4 of 6 (permalink) Old 07-13-2009, 07:24 PM
fueled by Colecovision
golfer's Avatar
Garage
http://www.winzerusa.com/ecat/index....a95610b79d753e
and copy/paste 722.97443 into the search bar
golfer is offline
post #5 of 6 (permalink) Old 07-13-2009, 07:47 PM
urbanwheeler's Avatar
wow, $25 isnt bad compared to a new harness.
4065 repair harness
'96 f-250, auto, shackle flip, solid axle, rsk, high/crossover steering, 3.73's, true trac's front and rear, trac bars, gt4202, 7.3 ic, idm mod, ccv mod, A1000, 4-line DIY Gen3, dual ipr's, casserly 350/200's, arp studs, 910's, pushrods, elec. fan, 2-stage nitrous, fluidampr.
[SIGPIC][/SIGPIC]
urbanwheeler is offline
post #6 of 6 (permalink) Old 07-13-2009, 09:54 PM Thread Starter
Thanks for all the replies, I was trying to locate one locally (within Canada), but Ford will only sell a complete harness, so I ordered the pigtails from swampsdiesel.
