low pressure cyling switch part number - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 07-13-2009, 03:43 AM Thread Starter
PSN nerd
does anybody have the number for it? i have the rectangle shaped plug, with 11/16 nut. the one they gave me has the round plug which i was gonna change out and the 9/16 nut on it.
they told me the rectangle one is discontinued, and the round plug one is the new one just have to change the plug out. but it has the smaller fitting. the "new" plug is the same one as the super duties. my cycling switch is leaking and not cycling well.
thanks!!
97 F250SC 4X4 4 LINKED ON AIR <- FOR SALE!!!!!!
00 F350CC 4x4 I NEED A FLATBED FOR IT!!!!! LET ME KNOW IF YALL KNOW ANYBODY THAT HAS ONE
JAKE is offline
post #2 of 5 (permalink) Old 07-13-2009, 08:41 PM
racehauler's Avatar
Re: low pressure cyling switch part number
What is a cycling switch?
Describe it a little bit because I don't think that's the terminoligy that we are used to.
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #3 of 5 (permalink) Old 07-13-2009, 09:02 PM Thread Starter
PSN nerd
its the pressure switch that is on the dryer on the passanger side of the truck
JAKE is offline
post #4 of 5 (permalink) Old 07-14-2009, 12:26 AM
97 OBS PSD
Aaron Ford's Avatar
F3AZ19E561A
You need to ask for the R-12 switch. It is a 134 system, but they did not use the 134 switch in our trucks. Ask for a switch from an older truck.
I bought mine a few months ago. As far as I know, theye are not discontinued
HTH
Aaron
97 PSD 4X4 250K, Ron Holland/Banks 1.00 A/R, EBPV Delete, 3" DP, Kitty Delete, PHP Phoenix 6 POS, 140V IDM, Autometers on the Pillar,4" Intake, 17 degree SD pump, 18-20 psi depending on setting...
Aaron Ford is offline
post #5 of 5 (permalink) Old 07-14-2009, 12:48 AM Thread Starter
PSN nerd
thanks!!
JAKE is offline
