Quick Question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 07-12-2009, 09:10 PM Thread Starter
Was PSD0389
Matt_P's Avatar
Exclamation Quick Question
If I have my EBPV unhooked then do I need to attach the rod back up to the EBPV valve or is it ok to leave it off?
03 F-350 CCLB King ranch undergoing a 6.0 delete
99 Fummins- SOLD
95 F250- SOLD
08 6.4- Totaled 12/19/10
Matt_P is offline
post #2 of 14 (permalink) Old 07-12-2009, 11:43 PM
Wanna Do More Mods
Justin M's Avatar
Re: Quick Question
If you left it off, wouldnt that be the same as gutting it
Justin M is offline
post #3 of 14 (permalink) Old 07-13-2009, 01:39 AM
97 OBS PSD
Aaron Ford's Avatar
Re: Quick Question
Correct me if I am wrong, but the rod should have 10lbs pressure to hold the valve open. The valve itself has no sping pressure to keep it open. If you left the rod disconnected, you would need to wire the valve in the open position. I gutted mine completely. Wish someone would come up with a DP that deletes it and has a slower bend right after the turbo.
Aaron
97 PSD 4X4 250K, Ron Holland/Banks 1.00 A/R, EBPV Delete, 3" DP, Kitty Delete, PHP Phoenix 6 POS, 140V IDM, Autometers on the Pillar,4" Intake, 17 degree SD pump, 18-20 psi depending on setting...
Aaron Ford is offline
post #4 of 14 (permalink) Old 07-13-2009, 03:47 AM
OEM Moderator
Tom S's Avatar
Re: Quick Question
I believe if you leave the rod hanging you will end up with a oil leak as the piston is now cocked in the bore. I would not let it hang if it was me.
Tom S is offline
post #5 of 14 (permalink) Old 07-13-2009, 06:09 AM
SLOW LEARNER
TERRCO's Avatar
Re: Quick Question
Mine started leaking almost right away after just leaving it hanging.
94 F250 4x4 SC Origanlly IDI,Currently 97 PSD,F350 springs,axles,all of the below.38R 1.15AR,CON OFE,TW 6 Position,Tymar,DP,Adrenaline,Straight piped,Stage II injectors,Electric fuel,6.0 IC,Guages
TERRCO is offline
post #6 of 14 (permalink) Old 07-13-2009, 11:46 AM
Senior Member
Larry_Dubya's Avatar
Re: Quick Question
I cut my rod off stuck it back in and plugged the hole with a 1/4" pipe plug. Ain't had no trouble yet out of it.
'97 F-350 4-WD
E4OD 3.55 gears
7.3 I-C stage 1's
38R
Termy modded 17*
Tru-Cool 4739
Swamps IDM Mod
Larry_Dubya is offline
post #7 of 14 (permalink) Old 07-14-2009, 06:29 PM
97 OBS PSD
Aaron Ford's Avatar
Re: Quick Question
I did the same thing. As I was not sure exactly how the oil circuit worked, I did not want to risk dumping the turbo's oil supply back to the sump. I cut the rod and reassembled the EBPV actuator with a pipe plug in the hole. I then pulled the plate and shaft out and sealed the lower hole with a 1/2 inch bolt and nut.
Works well.
Aaron
post #8 of 14 (permalink) Old 07-20-2009, 03:25 AM
Re: Quick Question
There is a new pedistal available with all that stuff gone and then you can put the banks power elbo on. That gets rid of it all. The your up to 4" better flow. Do the wicked wheel and new O rings wile your at it
2000 F-350 7.3 PSD 4X4 exstended cab 200 K Wicked wheel" open stacks, Banks power elbow, New GP New Injectors
Channing is offline
post #9 of 14 (permalink) Old 07-20-2009, 03:51 AM Thread Starter
Was PSD0389
Matt_P's Avatar
Re: Quick Question
Thanks for the help guys
huh? 4" better flow? now you lost me. I put a bigger turbo on, not to mention the stock obs turbos have what is called a wicked wheel in the first place, and I put the new o rings on with the d66.
99 Fummins- SOLD
95 F250- SOLD
Matt_P is offline
post #10 of 14 (permalink) Old 07-20-2009, 03:37 PM
Re: Quick Question
With the banks power elbow you do away with the EBPV completely. this brings your turbo outlet and down pipe up to 4". The pedestal upgrade does away with the leaking actuator and then you need the plug in chip for the end of the actuator wire
Channing is offline
