Brake light - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 07-12-2009, 05:59 AM Thread Starter
psdmike's Avatar
Brake light
Every couple of days that i drive my truck my brake light will come on. Its off when i start driving but a couple miles down the road it lights up and then gos off. Anyone had this problem.
1997 F350 Crew Cab, 7.3, 4x4, 5SP Short Shift kit, 5" RSK SD V Code springs, DIY Intake, 5" Exhaust with 30" FTE Resinator, intercooled, TS chip.
psdmike is offline
post #2 of 4 (permalink) Old 07-13-2009, 02:59 PM
Cratos's Avatar
Re: Brake light
CK your vac pump how do the brakes feel when it is on?
Blue 2012 XLT SCLB 4X4 , 38,550 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter.
Cratos is offline
post #3 of 4 (permalink) Old 07-13-2009, 10:00 PM Thread Starter
psdmike's Avatar
Re: Brake light
Brakes are fine. Even when it lights up nothing changes.
psdmike is offline
post #4 of 4 (permalink) Old 07-14-2009, 04:52 AM
SLOW LEARNER
TERRCO's Avatar
Re: Brake light
Check the brake switch at the brake pedal. Mine went out was acting similar.
94 F250 4x4 SC Origanlly IDI,Currently 97 PSD,F350 springs,axles,all of the below.38R 1.15AR,CON OFE,TW 6 Position,Tymar,DP,Adrenaline,Straight piped,Stage II injectors,Electric fuel,6.0 IC,Guages
TERRCO is offline
