Rattling noise... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 07-10-2009, 10:46 PM Thread Starter
Rattling noise...
I noticed about a week ago my truck is having a rattle in it right at 2000rpm, it sounds like a loose heat shield vibrating but i have checked everything under the hood of the truck to find it and it still does it. Also, at idle it wants to miss/lope a little bit but once you give it a little throttle it smooths right up. Any ideas? The truck is a '97 with 136k.
Work 2011 6.7 Ford F-350 Ex/cab Long Bed Dually, Stock.
Toy 1997 F-350 White RC/LB MBRP exhaust & DP Tuner.
RedBull_04 is offline
post #2 of 9 (permalink) Old 07-10-2009, 11:00 PM
Dairy Mechanic
Magnum PD's Avatar
Re: Rattling noise...
Ain't sure, not your turbo is it?
96 Ford F-350 200 cc's, Electric fuel system, TS chip, 17 oil pump, Banks intercooler, 3" intake manifolds, SNOW Water-Meth system, South Bend DxD 3600, Banks brake, 4" stacks. Tuff country ladder bars.
IH RULES Not a 6.0 fan, engine out right now.
Magnum PD is offline
post #3 of 9 (permalink) Old 07-10-2009, 11:41 PM Thread Starter
I pulled the intake boot off and checked for play, it has zero play. The truck has been smoking more than normal lately too, Which is what made me think it was the turbo going out.
post #4 of 9 (permalink) Old 07-11-2009, 06:21 PM
Dairy Mechanic
Magnum PD's Avatar
No oil puddles under the truck, white smoke, blue smoke, using much oil?
post #5 of 9 (permalink) Old 07-12-2009, 03:31 AM Thread Starter
No oil under it, hasnt burnt any oil either. Its blowing black smoke...ive tried everything i can think of to figure it out but havnt had any luck! Thanks for the help!
post #6 of 9 (permalink) Old 07-12-2009, 03:34 AM
Harl
Harl's Avatar
Send a message via AIM to Harl
I wonder if its the 2 pice flywheel comeing apart.. We got 2 powerstroke with the junky 2 pice flywheel and when the motors at idle it will miss and starts rattleing.. Also when driveing some times.. Auto or manual?
Cody,17
DD-1996 F250 Powerstroke, 5speed, 4x4 ecsb
Mods: GlowShift Gauges-Boost, Pryo, Oil psi and Fuel psi. DIY 6637 Intake, 160/100's, Wildman 6pos, Stage 2 water/meth, D66, TE HPOP, Vailer Clutch, Custom Bars and 5in turbo back....
PT-1995 F350- totaled
Soon to be brought back to a 1992
Harl is offline
post #7 of 9 (permalink) Old 07-12-2009, 03:41 AM Thread Starter
Auto...it rattles dead on 2000rpm everytime
post #8 of 9 (permalink) Old 07-12-2009, 03:45 AM
Harl
Harl's Avatar
Can you try and get a video of it? That would help out alot.
Cody,17
Harl is offline
post #9 of 9 (permalink) Old 07-12-2009, 03:56 AM Thread Starter
Ill try and get one tomorrow night....thanks for all the help!
