Is my oil cooler leaking - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 07-09-2009, 10:18 PM Thread Starter
gnxtc2's Avatar
I'm noticing my coolant level keeps dropping ever so slightly, I add then a few weeks later it has fallen.
I replaced the water pump (new) and hoses this past Jan.
I was at the Int'l dealer to get my up pipes and misc items for my donuts replacement, he asked for my engine serial number. So I look by the oil cooler/filter to get the number and I see this:
So is it leaking?
Billy T.
[email protected]
'97 Black F250HD SC 3.55s, Punisher trans, PI Converter, Dana 60 RSK w/ V & C SD springs,
PIS 175/80s, HB Jr, Comp910s, Smith Bros PRs, ARPs, Fluidampr, IC, E-Fuel, CJC Traction blocks, HFHV IDM, T4/BASB, 262K
Other vehicles
-1987 Buick Grand National (Staged)
-2004 Mercury Marauder
-1993 Geo Prizm (beater)
-2016 F350 DRW Utlimate
gnxtc2 is offline
post #2 of 8 (permalink) Old 07-09-2009, 11:19 PM
Member
vapstroke's Avatar
Re: Is my oil cooler leaking
You need to pressure test the cooling system and look for leaks.
Swamps, ITP diesel, DP tuner, BTS, Stecher Performance Diesel, DieselSite
vapstroke is offline
post #3 of 8 (permalink) Old 07-09-2009, 11:20 PM
i guess im blind but i dont see whats leaking
02 f250
countryboyrob is offline
post #4 of 8 (permalink) Old 07-09-2009, 11:59 PM
The Original
BigStroker's Avatar
He is referring to the rust on the cooler caps.
I agree need to pressure the system and check for leaks.
Personally if your oil cooler was leaking that much you should be seeing your oil turn milky.
I bet if it is leaking anywhere its around the injectors
[CENTER]1994 F350 4x4 5spd, 1995 F250 4x4 5spd, 1996 F250 4x2 auto, 1997 F350 4x4 auto, 1997 F250 4x2 auto
#27
BigStroker is offline
post #5 of 8 (permalink) Old 07-10-2009, 12:49 AM
oh ok thanks for the info
02 f250
post #6 of 8 (permalink) Old 07-10-2009, 02:11 AM
Fixing Broken Stuff
toolmangary's Avatar
It looks like you might have something going on there, I have replaced the ends of the oil cooler also because the antifreeze had eaten through the aluminum from the inside out. Do you have the coolant additive in your antifreeze?
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #7 of 8 (permalink) Old 07-10-2009, 02:36 AM Thread Starter
gnxtc2's Avatar
If the coolant is leaking externally, there will be no milkshake.
Yes, have the DCA-4.
Probably the best thing to do is pressure test it.
Billy T.
[email protected]
Other vehicles
gnxtc2 is offline
post #8 of 8 (permalink) Old 07-10-2009, 04:53 AM
Fixing Broken Stuff
I would pressure test it with the engine running next. Do you know if if always had the additive in it? The truck that I'm thinking about that I worked on ended up needing both oil cooler ends, a water pump and a heater core. I couldn't believe what the inside of the oil cooler ends and the water pump looked like, and the water pump was less than one year old. If you replace the oil cooler ends you will need new o-rings and gaskets, lube the o-ring and press it back together.
2004 Jetta TDI
1956 F100
