another crank but no start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 07-07-2009, 10:06 PM Thread Starter
TRUBBS's Avatar
i was drving down the freeway in my buddies 97 and all of a sudden it just shut off, it will crank over but wont start, ive changed the fallowing items and still nothing. cps,pcm,icp, ipr, and i was told to unplug the idm and see if it started with it unplugged, tried it and still nothing. what else could be wrong?
TRUBBS is offline
post #2 of 8 (permalink) Old 07-07-2009, 10:10 PM
Harl
Harl's Avatar
Send a message via AIM to Harl
Re: another crank but no start
Does the tach move when cranking? Any kind of smoke whiel trying to start?
Cody,17
DD-1996 F250 Powerstroke, 5speed, 4x4 ecsb
Mods: GlowShift Gauges-Boost, Pryo, Oil psi and Fuel psi. DIY 6637 Intake, 160/100's, Wildman 6pos, Stage 2 water/meth, D66, TE HPOP, Vailer Clutch, Custom Bars and 5in turbo back....
PT-1995 F350- totaled
Soon to be brought back to a 1992
Harl is offline
post #3 of 8 (permalink) Old 07-07-2009, 10:25 PM
Definately WON'T start with the idm unplugged, that's what tells your injectors to open!! Who told you that???
I hope you haven't BOUGHT all those items you said you changed, that's a tone of money just to throw parts at a problem.
Did you check fuse #22? Do you have fuel pressure? Is there oil in the engine?
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air, Beans tunes on VA 4 position chip, Adrenaline HPOP, VDO boost/pyro/outside temp gauges, Ford digital AIC, DPPI downpipe, gutted EBPV, modded turbo ped, Con OFE, add-a-leafs front/rear, Monroe Reflex shocks, Milemarker 449SS hubs...coming soon: 6.0 IC...wish list: Stage 2's
nashvillebill is offline
post #4 of 8 (permalink) Old 07-07-2009, 10:35 PM Thread Starter
TRUBBS's Avatar
all the parts came off of a parts truck that ran but threw a rod so i know that they are working. it will start and run off of eather but thats it. i dont remeber who but it was on here when MY computer went out someone said to unplug the idm . and yes their is oil in the motor, just changed it with amsoil about a week ago.
any ideas?
TRUBBS is offline
post #5 of 8 (permalink) Old 07-07-2009, 10:49 PM
cattle farmer
powerstroke742008's Avatar
when you turn the key on does the check engine light stay on?
Thomas,
97 f350 cclb-7.3
sticks,clutch,bars
05 f350 cclb-6.0
deleted, studed
powerstroke742008 is offline
post #6 of 8 (permalink) Old 07-07-2009, 10:54 PM
if it fires with ether, sounds like a fuel delivery issue. Whats your fuel pressure? Put a dial-type tire pressure gage on the Schrader valve on the FPR while somebody cranks.
Is there fuel in the fuel canister by the way?
And check Fuse 22
post #7 of 8 (permalink) Old 07-08-2009, 01:19 AM
Crusty old Bastich
3-StarJ.R.'s Avatar
You may have confused IDM with people saying to unplug the ICP sensor for a default test of the icp sensor. Fuse 22 handles the pcm and the fuel bowl heater. The heater is bad about shorting out and killing the pcm by frying the fuse. DO NOT use ether with glow plugs....motor go BOOM!
Jim
96 CC 2wd Dually
BDP engine build
BDP D-66
BDP/Casserly Hybrids
BDP twin pump fuel system
Hypermax Rods
Caltracs
Detroit locker
FactoryTech tranny
3-StarJ.R. is offline
post #8 of 8 (permalink) Old 07-08-2009, 03:59 AM
Harl
Harl's Avatar
oops.. we were doin that the other day..
Anyway Just unscrew the Fuel bowl cap a little and have someone crank it and ull no if its got fuel psi. Does it have dual fuel tanks?
Cody,17
Harl is offline
