Tranny shudder? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 07-07-2009, 02:52 AM Thread Starter
Question Tranny shudder?
I dont know how to explain correctly but the issue is:
When the tranny make changes between gears (more noticeable between 2nd to 3th and to 4th , has a short shake (less than one second) and it is more intense or severe (but not longer) at WOT. I dont know if that is a shudder or not, and what could be the culprit of it: the tranny converter? or the clutches in the tranny?
The tranny changes good and the TC locks fine and when it has to do it. No OD light flashing.
Any ideas?
Thanks in advance.
243000 in the odo.
F-250 PSD 1996 ext.cab 2WD, Short bed, E4OD.
STROKER #1 is offline
post #2 of 10 (permalink) Old 07-09-2009, 02:14 AM Thread Starter
Exclamation Re: Tranny shudder?
No one???
post #3 of 10 (permalink) Old 07-09-2009, 02:35 AM
Guest
Posts: n/a
Re: Tranny shudder?
How many miles on your truck??
post #4 of 10 (permalink) Old 07-09-2009, 02:41 AM Thread Starter
Re: Tranny shudder?
243K in the odo. sorry my mistake since the firs post, only 143K. Thanks
post #5 of 10 (permalink) Old 07-09-2009, 02:47 AM
Guest
Posts: n/a
Re: Tranny shudder?
I had a similar problem with a 7.3 and it got worse. Turned out to be clutch plates in mine. It could be a number of things. Driveshaft U-joints can do some weird stuff also if there worn. Good luck
post #6 of 10 (permalink) Old 07-09-2009, 02:50 AM Thread Starter
Thumbs up Re: Tranny shudder?
Ok, thank you for your answer, I hope it is not that bad but who knows. time tell me.
Im going to check the u-joints.
post #7 of 10 (permalink) Old 07-09-2009, 03:09 AM
Fixing Broken Stuff
toolmangary's Avatar
Re: Tranny shudder?
How long has it been since the trans fluid was changed/flushed ?
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #8 of 10 (permalink) Old 07-09-2009, 03:52 AM
The Fireman's Avatar
Re: Tranny shudder?
Mine was doing something like that recently and now I'm buying a TC. If it has been a while since you changed the fluid, pull the pan and see if there is any clutch material in there.
Bryan
97 F250 SC LB 4x4 Auto 368,000 miles, AD's, 3in down pipe, Straight Pipe,EBPV deleted, DIY Intake, Racer X converter and valve body, Beans tunes
The Fireman is offline
post #9 of 10 (permalink) Old 07-09-2009, 04:28 PM
Guest
Posts: n/a
Re: Tranny shudder?
Good point Fireman. I flush mine every 25,000 or so. Very important..
post #10 of 10 (permalink) Old 07-09-2009, 08:31 PM Thread Starter
The fluid is fresh, less than 2 k miles.
the pan doesnt have in the bottom and magnet clutch material, only some sludge that I think is normal.
Thanks for the inputs
