Turbo exhaust housing bolts - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 07-06-2009, 04:01 PM Thread Starter
Got my turbo out, and I see one of the exhaust housing-to-turbo bolts is missing (not the EBPV housing bolts). Not broken, missing entirely...must've been left out from the factory (or else vibrated loose, unlikely) because this is the first time the turbo has come out.
Any reason I shouldn't use a stainless steel hex head bolt, or maybe stainless socket head cap screws to replace them? I'll use lockwashers and copper never-seize on them.
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air, Beans tunes on VA 4 position chip, Adrenaline HPOP, VDO boost/pyro/outside temp gauges, Ford digital AIC, DPPI downpipe, gutted EBPV, modded turbo ped, Con OFE, add-a-leafs front/rear, Monroe Reflex shocks, Milemarker 449SS hubs...coming soon: 6.0 IC...wish list: Stage 2's
nashvillebill is offline
post #2 of 4 (permalink) Old 07-06-2009, 04:13 PM
Member
vapstroke's Avatar
Re: Turbo exhaust housing bolts
stage 8 has locking fasteners that will not back out. I think ITP has them.
Swamps, ITP diesel, DP tuner, BTS, Stecher Performance Diesel, DieselSite
vapstroke is offline
post #3 of 4 (permalink) Old 07-06-2009, 07:00 PM
zilla68's Avatar
make sure you use plenty of anti sieze on them, so they won't gall up either going in or taking them back out sometime.
Chris
Moore, Oklahoma
1996 Ford F350 4x4 Crew Cab PSD
6637 tymar
285-75-16 BFG All Terrains/Weld Wheels
3:55 gears
Automatic with billet convertor, tugger and alto discs
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
post #4 of 4 (permalink) Old 07-09-2009, 08:33 AM
Terminator Nation
Ford dealer sells the bolts. I use NevrSeize and torque them to 17 ft-lbs. Any less and they may fall out and the housing eats up the wheel. Learned this the hard way.
old man dave is offline
