Oil leakin - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 07-06-2009, 05:43 AM Thread Starter
got another 7.3
smokinford07's Avatar
Send a message via AIM to smokinford07
Oil leakin
My truck has developed a pretty bad oil leak at the front of the motor, and the other one is coming from the back of the motor, I'm thinking the one up front is from the timing cover. Is that a big PITA to fix? My Next question is, where is the most likely spot the oil is coming from in the back? I've been told it's the rear main seal, is there anywhere else I should be looking? I get paid thursday and I'm buying the stuff to fix it all this weekend. Thanks for any input.
E99 (Red Truck) 4x4, 7.3 4"DP into 5" Flo-Pro exhaust, DIY tymar, 3/8ths fuel line with a holley blue pump,and a PHP Phoenix (stock, 65t, 80dd, 100 performance, 120race, no start) 140v IDM, 285/75/16 Goodyear Duratracs
E99 (Black Truck) 4x4 7.3, 6 speed with a junked motor right now
smokinford07 is offline
post #2 of 9 (permalink) Old 07-06-2009, 05:44 AM Thread Starter
got another 7.3
Re: Oil leakin
oh btw, motor has 70 thousand on it
post #3 of 9 (permalink) Old 07-06-2009, 05:48 AM
That thing got a Cummins?
nasty96's Avatar
Re: Oil leakin
Before you go changing the rear main, I would check the valve cover gaskets, the turbo O-rings, and the valley of the engine. If you have an oil/fuel leak in the valley, it will run down the back of the block and make it look like your rear main is leaking. Good luck
Ford makes it
, I break it
1996 F350 CCLB 4x4 Broke Built Auto
2000 Dodge 3500 5 Speed 4x4 450k and Counting
2001 Dodge 3500 6 speed 4x4 Fully loaded
nasty96 is offline
post #4 of 9 (permalink) Old 07-06-2009, 05:50 AM
psdmike's Avatar
Re: Oil leakin
EBPV Or HPOP O rings are probly leaking down the rear. Look in the vally of the motor to see were its coming from.
1997 F350 Crew Cab, 7.3, 4x4, 5SP Short Shift kit, 5" RSK SD V Code springs, DIY Intake, 5" Exhaust with 30" FTE Resinator, intercooled, TS chip.
psdmike is offline
post #5 of 9 (permalink) Old 07-06-2009, 05:54 AM Thread Starter
got another 7.3
Re: Oil leakin
What would be involved with the HPOP O rings?
post #6 of 9 (permalink) Old 07-06-2009, 07:45 AM Thread Starter
got another 7.3
Re: Oil leakin
and my other question is, where do i get some, local autozone doesn't carry anything for my truck
post #7 of 9 (permalink) Old 07-07-2009, 06:02 PM Thread Starter
got another 7.3
Re: Oil leakin
Does anyone know where I can get the HPOP O-rings at?
post #8 of 9 (permalink) Old 07-07-2009, 06:22 PM
Re: Oil leakin
powerstrokeshop.com, swamps, beans, ford, international, my guess
02 f250
countryboyrob is offline
post #9 of 9 (permalink) Old 07-10-2009, 02:17 AM
Fixing Broken Stuff
toolmangary's Avatar
Re: Oil leakin
There are some plugs on the end of the heads that can leak oil. The ones I have fixed were not to bad to do.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
