Dana 60 shafts - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 07-05-2009, 09:03 PM Thread Starter
gnxtc2's Avatar
Dana 60 shafts
Been chasing down a thumping noise coming from the front end ever since swapping in the D60 (5 years ago). I swapped in a '94 D60. I checked ball joints, tie rods, pitman arm, drag link, etc, etc.
Well...I think I found the problem, the axle shafts of the D60 are bouncing inside the tube. There are not not making contact with the tubes. Seems like splines inside the hub (Warn Premiums) are alittle sloppy. When I go over a bump, the shafts bounce and transmit the annoying thump.
When I bought the axle, I replaced everything except for the gears with new parts. Yes, I bought new Dana axles and U-joints because the old seal was leaking and cut a groove on the axle shaft. The parts ordered where bought according to BOM on the axle tube.
Is there a remedy for this or am I missing a part? I checked out Tom S Dana 60 parts illustrations and looks like I have everything.
Thanks
Billy T.
[email protected]
'97 Black F250HD SC 3.55s, Punisher trans, PI Converter, Dana 60 RSK w/ V & C SD springs,
PIS 175/80s, HB Jr, Comp910s, Smith Bros PRs, ARPs, Fluidampr, IC, E-Fuel, CJC Traction blocks, HFHV IDM, T4/BASB, 262K
Other vehicles
-1987 Buick Grand National (Staged)
-2004 Mercury Marauder
-1993 Geo Prizm (beater)
-2016 F350 DRW Utlimate
gnxtc2 is offline
post #2 of 4 (permalink) Old 07-06-2009, 04:44 AM
OEM Moderator
Tom S's Avatar
Re: Dana 60 shafts
If they are like the Dana 50 how are the needle bearings inside the spindle?
Tom S is offline
post #3 of 4 (permalink) Old 07-06-2009, 04:06 PM
Tater for President!
Re: Dana 60 shafts
I was thinking the same thing...
#31
1997 F-250 - SCSB - ZF-5, 4x4, 4.10, 17* HPOP, Tymar Intake, TWildman Tunes, SD IC, 4" Straight Exhaust, Dana 60 w/ 3.5" RSK and SD Springs all around on 35" BFG A/Ts - SOLD
2009 - 6.4L - Crew Cab/Long Bed - FX4 - 4" Pure Performance X-Factor Lift - 325/60/20 Duratracs -- FOR SALE
2014 - 6.7L - Crew Cab/Long Bed - Lariat 4x4 - Stock
PSDfreak is offline
post #4 of 4 (permalink) Old 07-06-2009, 09:53 PM Thread Starter
gnxtc2's Avatar
Re: Dana 60 shafts
Ah never thought about them, I'll take a look at them when I'm doing the front brake pads.
Billy T.
[email protected]
Other vehicles
gnxtc2 is offline
