Need Help Fast?????????????????? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 07-04-2009, 04:44 AM Thread Starter
userma3648's Avatar
Hey my Dad has a 1997 7.3 and it has a very rough ideal and it has oneheck of a rap to the motor! it comes and goes one day its fine the next its crap! when it runs rough it gets very hot! it dont have a temg gauge so i dont no what the temp realy are! O have no clue whats going on! and eather does he!
thanks for the help
08 6.4 with some goodies
userma3648 is offline
post #2 of 11 (permalink) Old 07-04-2009, 04:51 AM Thread Starter
userma3648's Avatar
Re: Need Help Fast??????????????????
and there is no codes coming up
post #3 of 11 (permalink) Old 07-04-2009, 01:04 PM
Lovin Life...
02BigD's Avatar
Smoke while it's idleing rough? Are the RPM's normal? Can you explain how it gets hot?
02-350. CCSB - Drivetrain by Stauffer, fuel by Swamps, air by Barder, tunes by Gearhead.
04-250. ECSB - In the shop...7.3 swap.
02BigD is offline
post #4 of 11 (permalink) Old 07-04-2009, 05:25 PM Thread Starter
userma3648's Avatar
Yes white smoke at ideal! it get hot when at ideal at 2 mins!
post #5 of 11 (permalink) Old 07-04-2009, 05:26 PM Thread Starter
userma3648's Avatar
Rmps are normal
post #6 of 11 (permalink) Old 07-04-2009, 07:27 PM
Lovin Life...
02BigD's Avatar
Sounds like (I'm far from expert) but injector issue, wether O ring, or an actual injector going bad. Can you get it on AE to do a check?
02BigD is offline
post #7 of 11 (permalink) Old 07-05-2009, 05:14 AM Thread Starter
userma3648's Avatar
we found oyt what it is! it is the first 2 injectors on the driver side!
thanks for the help
post #8 of 11 (permalink) Old 07-05-2009, 02:40 PM
Lovin Life...
02BigD's Avatar
Good deal, well, at least you know what the issue is. Get more details back here when you get them pulled. How did you figure out which ones?
02BigD is offline
post #9 of 11 (permalink) Old 07-05-2009, 10:22 PM Thread Starter
userma3648's Avatar
I pulled the cover and checked each one on the drver side! i checked hem out and the first to look like they were in a fire? they had no o-rings man they look like they went there the war
post #10 of 11 (permalink) Old 07-05-2009, 11:57 PM
Lovin Life...
02BigD's Avatar
Thanks for the info Mark. Did all of the brass washers come out? I've learned that's a possible issue point. Good luck with the new o rings.
Another thing in the equasion are the injector cups. Thinking out loud.
02BigD is offline
