Rough idle, feels like an injector out. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 07-03-2009, 10:21 AM Thread Starter
Kevin
I got a later 94 powerstroke, has a really rough idle and feels like a pretty good miss when i accelerate. feels like an injector out. just had ford place put 4 injectors put in a year ago. i hooked up a snap on scanner and injectors passed buzz test, and only code was ECT or EOC sensor out of range. how do i single out an injector? any help would be appretiated.
kevi is offline
post #2 of 5 (permalink) Old 07-03-2009, 04:23 PM
Patrick Feeley's Avatar
Re: Rough idle, feels like an injector out.
If you can hook up the scanner and do a cylinder contribultion test (make sure the truck is warmed up), that may help you figure out which cylinder(s) it could be. You may have a loose poppet screw underneath one of the injector solenoids. Cheers!
Patrick Feeley is offline
post #3 of 5 (permalink) Old 07-03-2009, 05:40 PM
mandkole's Avatar
Check the 4 harness plugs first to see if you can get the inj to come back by wiggling the plugs. If an injector is dead, you can identify it with the VC off and look for one that is not pumping oil. If you find it, first unplug it to see if it runs any different. If the poppet armature is loose, it may partially disable it or all the way. If its not the armature, then youre going much deeper...
2000 F250 CCSB-- GT4294R, 250/100s, Dahl/Fuelab, PHP, scan gauge, stock 17* pump
1994 F250 4x4 SC (sold)
1997 F250 CCSB 2wd (sold)
mandkole is offline
post #4 of 5 (permalink) Old 01-01-2010, 07:39 AM Thread Starter
Kevin
after cancelling out every injector one at a time, it ended up being two injectors out. thank for the help though
kevi is offline
post #5 of 5 (permalink) Old 01-05-2010, 01:08 AM
glad to hear you found the bad injectors
desertshark is offline
