Power steering hose - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 07-02-2009, 02:38 PM Thread Starter
zilla68's Avatar
Power steering hose
Ok,
i get my 6637 conversion done, and man it made a big difference. seems to run smoother, and much better.
anyways, i get it done, and the passenger up pipe gasket, and go for a test run, get on it and blow the damn power steering hose out of the fitting in the pump! truck gets hard to steer, so I pull over and see the actual fitting just hanging out of the pump like it came unplugged, so I stick it back in by hand, and limp back home. Now remember the threaded part is still in the pump, just the hose unplugged from its threaded fitting.
I run to advance and get another hose. I take the old hose off, and I can't for the life of me, get that hose barb to come back out of the fitting. I have the hose off the truck, but hell I stuck it back in by hand and couldn't get it back thru with a hammer after I took it off. Anyone ever had one come apart like that? I could understand if it wouldn't have just pushed back in, but it went in like nothing, very light pressure, and now trying to find out what happened it won't come back apart.
Very strange.
Chris
Moore, Oklahoma
1996 Ford F350 4x4 Crew Cab PSD
6637 tymar
285-75-16 BFG All Terrains/Weld Wheels
3:55 gears
Automatic with billet convertor, tugger and alto discs
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
post #2 of 11 (permalink) Old 07-02-2009, 03:09 PM
Don't EFN worry about it
Aljay's Avatar
Re: Power steering hose
That hose design sucks mine is real loose. Might have galled together .
Tuned by T Wildman
Aljay is offline
post #3 of 11 (permalink) Old 07-02-2009, 04:00 PM
Senior Veteran Member
Centxdiesel's Avatar
Garage
I used to always keep a spare in my truck. If I turned sharp to the left or right ( can't remember which way it was) it would blow it off. I think I would be turning hard all the way and hit the stop and the pressure would blow the hose out. Never had the piece stay inside there though.
Centxdiesel
1997 F250 XL SC, 512HP 1019TQ,
30% nozzle Hybrids from [email protected]
Adrenaline, Beans D-66,Beans E-Fuel,Valair Ceramic-Kevlar clutch.
Awesome Tuning by: Matt: from:
Centxdiesel is offline
post #4 of 11 (permalink) Old 07-02-2009, 04:23 PM
mandkole's Avatar
There is a pressed in metal threaded port in the reservoir body that is part of the reservoir. A male thread swivel nut that is part of the hose assembly needs to come out. Don't know why its not coming out...
Do not count on that tube end staying in the swivel nut. I agree with Al that its a very crappy design. Mine finally gave it up (fortunately in the driveway) and I just replaced it last week. Changing the hose assembly is a PIA and I also did the return/cooler line at the same time....
2000 F250 CCSB-- GT4294R, 250/100s, Dahl/Fuelab, PHP, scan gauge, stock 17* pump
1994 F250 4x4 SC (sold)
1997 F250 CCSB 2wd (sold)
mandkole is offline
post #5 of 11 (permalink) Old 07-03-2009, 12:27 AM
gnxtc2's Avatar
Mine blew out in the Homey Cheapo parking lot. The fitting blowing off from the pump is common.
Billy T.
[email protected]
'97 Black F250HD SC 3.55s, Punisher trans, PI Converter, Dana 60 RSK w/ V & C SD springs,
PIS 175/80s, HB Jr, Comp910s, Smith Bros PRs, ARPs, Fluidampr, IC, E-Fuel, CJC Traction blocks, HFHV IDM, T4/BASB, 262K
Other vehicles
-1987 Buick Grand National (Staged)
-2004 Mercury Marauder
-1993 Geo Prizm (beater)
-2016 F350 DRW Utlimate
gnxtc2 is offline
post #6 of 11 (permalink) Old 07-03-2009, 03:03 AM
Terminator Nation
NAPA hose replacement is rumored to be better than the Ford hose.
old man dave is offline
post #7 of 11 (permalink) Old 07-04-2009, 12:38 AM Thread Starter
zilla68's Avatar
well the one I bought from advance seems to be much better. the end kind of looks flared instead of the stock one that looks to be just stuck in there.
I can't believe that someone hasn't figured out a fix for it. maybe like a flared hose end with the same threaded fitting.
Chris
Moore, Oklahoma
6637 tymar
3:55 gears
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
post #8 of 11 (permalink) Old 07-04-2009, 12:40 AM Thread Starter
zilla68's Avatar
I probably didn't explain it well enough, but the threaded port in the reservoir body is still in there, its the threaded part that is on the hose itself I was referring to.
Did you guys just push yours back in also, and refill, or get a new hose?
Chris
Moore, Oklahoma
6637 tymar
3:55 gears
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
post #9 of 11 (permalink) Old 07-04-2009, 07:39 PM
mandkole's Avatar
Take out the threaded part and get a new hose assembly. I paid about $45 for both supply and return assemblies. Plan on some time to get access to the steering box connections. I removed the ac comp, vaccum pump, and the whole accessory bracket on the drivers side (with steering pump still attached).
mandkole is offline
post #10 of 11 (permalink) Old 07-05-2009, 02:59 AM
Aljay's Avatar
I work at oriellys I will order one up and see what it looks like.
Tuned by T Wildman
Aljay is offline
