Brake problems. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 07-01-2009, 12:01 AM Thread Starter
Brake problems.
The past couple times I've drove my F-350, after the motor has warmed up and been driving for a bit I'll start having brake problems. The brake pedal becomes extremely hard to depress and the truck will not slow down, hardly any at all. Pumping the brakes does not help at all, still the same result. Its all I can do to make it safely home.
I've asked a few folks and they've said perhaps: Vacuum pump, vacuum hose are two possibilities?
Any help is appreciated.
1995 F-350 CC - Dually Longbed Under work...
S+B Intake. MBRP 3"DP-4"Exhaust. TS Performance 6 Bank.
Stroke It Again is offline
post #2 of 6 (permalink) Old 07-01-2009, 01:30 AM
Terminator Nation
Re: Brake problems.
Is your brake warning light lit?
old man dave is offline
post #3 of 6 (permalink) Old 07-02-2009, 02:21 AM
Talking Re: Brake problems.
My money is with the vaccum pump.
F-250 PSD 1996 ext.cab 2WD, Short bed, E4OD.
STROKER #1 is offline
post #4 of 6 (permalink) Old 07-03-2009, 12:50 AM
Yoslick's Avatar
Re: Brake problems.
yup, check the vacuum pump!!
DCC(SW/MTS) USN-Ret. 75-95
96 F-250 DIY Intake (NAPA 6637)
3" DP
Gutless Kitty
14.6k Mod
Yoslick is offline
post #5 of 6 (permalink) Old 07-07-2009, 09:13 PM Thread Starter
Re: Brake problems.
I replaced the vacuum pump today and the brakes startin workin just fine.
The vacuum pump has...exploded out toward the cold air intake. Odd.
post #6 of 6 (permalink) Old 07-07-2009, 09:33 PM
Glad to hear that the brakes are working fine.
