Up pipes,donuts & misc things - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 06-30-2009, 02:49 AM Thread Starter
gnxtc2's Avatar
Last time I had my turbo off, the collector was loose. I am figuring it's donut time. I would really like a set of the updated Int'l bellowed up pipes but those are around $900.
So what are my options? Get the brass donuts from Bean? Also anyone know the part number for the OEM up pipes just in case my original ones are cracked or have eroded?
The plan is to remove the trans and tackle the up pipes from underneith rather than lying on top of the engine.
Anything else I should while I'm there?
Oh BTW, my boost has been gradually falling and hearing "shhhhhhhhhhh" by the firewall everytime I get into boost.
Thanks
Billy T.
[email protected]
'97 Black F250HD SC 3.55s, Punisher trans, PI Converter, Dana 60 RSK w/ V & C SD springs,
PIS 175/80s, HB Jr, Comp910s, Smith Bros PRs, ARPs, Fluidampr, IC, E-Fuel, CJC Traction blocks, HFHV IDM, T4/BASB, 262K
Other vehicles
-1987 Buick Grand National (Staged)
-2004 Mercury Marauder
-1993 Geo Prizm (beater)
-2016 F350 DRW Utlimate
gnxtc2 is offline
post #2 of 4 (permalink) Old 06-30-2009, 02:52 AM
Don't EFN worry about it
Aljay's Avatar
Re: Up pipes,donuts & misc things
You may have to do some from the top .
Tuned by T Wildman
Aljay is offline
post #3 of 4 (permalink) Old 06-30-2009, 03:24 AM
Patrick Feeley's Avatar
Turbo Exhaust Up-Pipes
(Ford) F4TZ-6K854-A (Driver’s side)
(Ford) F6TZ-6K854-A (Passenger side)
Turbo Up-Pipe Bolts
(International) 1821640C1 (long for manifold end, 4 required), part number was superseded by part number W300013
(International) 1822895C1 (short for turbo collector end, 4 required), try 1844044C1 which will cross to W301160 which was superseded by W301640
(Ford) 40066R1 (Nuts, 4 required), superseded by W300051
Cheers!
Patrick Feeley is offline
post #4 of 4 (permalink) Old 06-30-2009, 03:34 AM
Pulled the transmission, up-pipes, and turbo last weekend. Even with the transmission off, the drivers side up-pipe was difficult to remove. I had to jack the engine up to finally get it to clear between the engine and firewall.
Surprisingly, that donut was still so tight that I'm having difficulty pulling the drivers pipe out of the turbo collector. So i guess I'm going back with the Ford donuts, it lasted 15 years and 110K miles.
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air, Beans tunes on VA 4 position chip, Adrenaline HPOP, VDO boost/pyro/outside temp gauges, Ford digital AIC, DPPI downpipe, gutted EBPV, modded turbo ped, Con OFE, add-a-leafs front/rear, Monroe Reflex shocks, Milemarker 449SS hubs...coming soon: 6.0 IC...wish list: Stage 2's
nashvillebill is offline
