Injector Plug grommet - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 06-29-2009, 05:22 AM Thread Starter
wynndaddy's Avatar
Does anybody know were to get the rubber gasket that goes on the glowplug / injector plug ? I called the local dealer and they said they could not get them without ordering a new harness . I just cant believe that , though someone might know ?
1997 cc swb 4x4
wynndaddy is offline
post #2 of 9 (permalink) Old 06-29-2009, 05:35 AM
Don't EFN worry about it
Aljay's Avatar
Re: Injector Plug grommet
Rubber gasket ?????????
Tuned by T Wildman
Aljay is offline
post #3 of 9 (permalink) Old 06-29-2009, 05:46 AM Thread Starter
wynndaddy's Avatar
Yeah it goes on the plug where it connects to the valve cover gasket . The ones on mine are a light blue . I dont have to have it but if I could find one I would like to put it back on .
1997 cc swb 4x4
post #4 of 9 (permalink) Old 06-29-2009, 05:51 AM
Aljay's Avatar
Oh ok gotcha now the weather proof grommets . I have an old harness PM me your addy. I will mail you 2 of them if ya want.
Tuned by T Wildman
Aljay is offline
post #5 of 9 (permalink) Old 06-30-2009, 12:45 AM
Patrick Feeley's Avatar
You could also use the ones that come in the external harness repair kits:
Valve Cover External Harness Repair Kits (contains 4 hard shells w/seals, w/o pins)
(Ford) F7TZ-14489-BA (94-96) w/o pins
(Ford) F7TZ-14489-AA (97) w/o pins
(International) 1830829C91 w/o pins
Kind of pricey that way, but you would still heve the rest of the kit for future repairs. Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3” DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
post #6 of 9 (permalink) Old 06-30-2009, 12:47 AM
Aljay's Avatar
I have the repair kits as well Lost the damn tool that comes with the shell kit tho
Tuned by T Wildman
Aljay is offline
post #7 of 9 (permalink) Old 06-30-2009, 01:33 AM
ianjadkins's Avatar
Try an International truck shop. They make the engine. Navistar DT444 = 7.3L powerstroke.
95 Extended cab Long Bed XLT
Dana 60
Tymar Intake
Sport Comp Gauges
FPR Shim
3" Dp - 4" Exhaust
ianjadkins is offline
post #8 of 9 (permalink) Old 07-01-2009, 04:30 AM Thread Starter
wynndaddy's Avatar
Thanks Aljay , I appreciate it .
1997 cc swb 4x4
post #9 of 9 (permalink) Old 07-01-2009, 12:47 PM
Senior Veteran Member
Centxdiesel's Avatar
Garage
Dorman has a UVC kit woth valve cover gasket, inside connectors and outside connectors with pigtail attached for around $65.00. I got mine from O'reileys cheaper than dealer. They worked fine. Just my .02
Centxdiesel
1997 F250 XL SC, 512HP 1019TQ,
30% nozzle Hybrids from [email protected]
Adrenaline, Beans D-66,Beans E-Fuel,Valair Ceramic-Kevlar clutch.
Awesome Tuning by: Matt: from:
Centxdiesel is offline
