urgent turbo boot help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 06-26-2009, 08:36 PM Thread Starter
zilla68's Avatar
I just pulled the boot off the turbo that is on the front side, connects to a metal tube that connects to the stock air filter box. part number is 1820102c2, that is on the tube, anyways what does a guy use as a replacement. Ford said 145 bucks, but that can't be right, hell the boots about 6 to 8 inches long. Please help
It is an orange boot, stock
Chris
Moore, Oklahoma
1996 Ford F350 4x4 Crew Cab PSD
6637 tymar
285-75-16 BFG All Terrains/Weld Wheels
3:55 gears
Automatic with billet convertor, tugger and alto discs
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
post #2 of 16 (permalink) Old 06-26-2009, 08:40 PM
Don't EFN worry about it
Aljay's Avatar
Re: urgent turbo boot help
145 is the upgrade KIT it gives you everything to convert to the black hose .
My understanding from ford was the orange hose was discontinued !
Tuned by T Wildman
Aljay is offline
post #3 of 16 (permalink) Old 06-26-2009, 09:29 PM
Tater for President!
Yep...Get the upgrade, the orange one is junk
#31
1997 F-250 - SCSB - ZF-5, 4x4, 4.10, 17* HPOP, Tymar Intake, TWildman Tunes, SD IC, 4" Straight Exhaust, Dana 60 w/ 3.5" RSK and SD Springs all around on 35" BFG A/Ts - SOLD
2009 - 6.4L - Crew Cab/Long Bed - FX4 - 4" Pure Performance X-Factor Lift - 325/60/20 Duratracs -- FOR SALE
2014 - 6.7L - Crew Cab/Long Bed - Lariat 4x4 - Stock
PSDfreak is offline
post #4 of 16 (permalink) Old 06-26-2009, 10:26 PM
I caught a bunch of $hit from people last time I answered this question,but here I go again. I recently had the same problem with my truck Fords $145 "kit" comes with alot of BS I didn't feel was necesary. Intakehoses.com has a relacement hose for around $55 I belive. That's how I fixed my truck,right,wrong or otherwise.
1997 250 Crew cab shorty
4" BDS lift
315s on 1059 Pro Comps
Intercooled
Lots of misc bolted on
974DR is offline
post #5 of 16 (permalink) Old 06-26-2009, 10:38 PM Thread Starter
zilla68's Avatar
I saw that when I googled the part number, do you know which one it is?
Chris
Moore, Oklahoma
6637 tymar
3:55 gears
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
post #6 of 16 (permalink) Old 06-27-2009, 12:59 AM
Patrick Feeley's Avatar
The update kit is about $87 at Powerstrokeshop.com (F7TZ9C681AA). I don't mind paying a bit more for the factory kit (I've done it on both my trucks, 1994 and 1997) as it is nice and stout (especially when compared to the wimpy original orange boot that is no longer available). Cheers!
Patrick Feeley is offline
post #7 of 16 (permalink) Old 06-27-2009, 01:13 AM Thread Starter
zilla68's Avatar
awesome, I will order from them, I tried to look up the original number but couldn't find it, i will try that number.
thanks alot it is much appreciated.
Chris
Moore, Oklahoma
6637 tymar
3:55 gears
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
post #8 of 16 (permalink) Old 06-27-2009, 01:31 AM
Aljay's Avatar
Only reason I throw the KIT up is I have done a whole slew of them yes the orange one can be had but how do it stack up with O.E . Air side is not where you need to cut corners.
Tuned by T Wildman
Aljay is offline
post #9 of 16 (permalink) Old 06-27-2009, 04:55 PM
Just thought I would throw this out there, just to clear up any confusion. I know that the orange boot is junk, obviously thats why they don't make it anymore. The hose that I put on my truck is not the stock replacement boot. The stock piece in my best guess is made of some type of rubber, which over time looks like it softens and fails. The hose that I bought from Intakehoses.com appears to be made of silicone, it's similar looking to intercooler boots. Obviously silicone is better suited to be under the hood of a truck. So going the way I did, I replaced the failed part with a better replacement. Buying the OEM "update kit" you are replacing alot of other parts that are still in working order. That's all I'm tying to say I'm not promoting the place I got my hose and I'm not bashing the Ford kit. Just throwing out another cheaper option.
4" BDS lift
Intercooled
974DR is offline
post #10 of 16 (permalink) Old 06-28-2009, 12:43 AM
original "REZNECK"
kbnord's Avatar
thanks for the cheaper option not every one on here has a surplus of funds and 30 bucks might not sound like much but to some of us that is alot thanks again!!!!!
twice tottalled
01 F250 cc 4x4 straight pipe, custom front and rear bumpers, 1 ton rear susp, flatbed, TS Chip, king ranch rims, 315 tires
Since when do 7.3's puke coolant like an overfilled hooker on a busy night ?
kbnord is offline
