F250 to F350 Differences? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 11-26-2007, 12:21 AM Thread Starter
Got 'Er Did
lownslow's Avatar
dotting my i's and crossing my t's her
F350 Just has a D60, different front springs, different trans cross member, and 4 inch blocks.......anything i am missing?
2009 Mustang GT Premium 5spd
BBK Long Tube Headlers and Off Road X Pipe
waiting for the squeeze
1995 F350 Crew Long 4x4 Dually
Powerstroke
Auto
4 inch MBRP
lownslow is offline
post #2 of 14 (permalink) Old 11-26-2007, 04:04 AM
OBS junkie
Cat_Rebel's Avatar
Re: F250 to F350 Differences?
I think the brakes might be slightly larger but I can't say for sure. I think you pegged it pretty good.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #3 of 14 (permalink) Old 11-26-2007, 05:44 AM
Oooo, White Lightning !
Dieselboy's Avatar
The rear leafs are beefier.....And one says F-250 and one says F-350....Other than that you pretty much got the just of it...
Race truck
2002 F-350XL RC/LB
NADP Race Trans/PCS'd
Lowered w/ traction bars
Unlimited 450/400s
S475 on Irates mount
TE 17* with Gen3
DI Headers
Dieselboy fuel system
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
Dieselboy is offline
post #4 of 14 (permalink) Old 11-29-2007, 02:07 AM
Exclamation Re: F250 to F350 Differences?
In some forum I read that the frame has a different thickness.
F-250 PSD 1996 ext.cab 2WD, Short bed, E4OD.
STROKER #1 is offline
post #5 of 14 (permalink) Old 11-29-2007, 03:22 AM
Bugman's Avatar
I believe that on OBS trucks the only difference is the 4" blocks in the rear and frount springs. The F250 are heaver duty due to the TTB frount end. Everything else is the same.
Jim
Bugman is offline
post #6 of 14 (permalink) Old 11-29-2007, 04:53 PM
< pissed off pumkin.
skylinedan's Avatar
Talking Re: F250 to F350 Differences?
I know the front axles are diferent because a 350 is a staright axle where as the 250 istwo peice.
Dan
2003 F-350 4x4, Ext cab. 7.3 AFE stage II 4" turbo back exhaust, garret GTP 38, 1.15 van turbine housing,EBPV deleated, non waste gated, ATS compresor housing, WW II, bellowed up pipes, CFM + spyder conversion, Hydra chip with Bill's tunes, CCV mod, Hutched, harpooned, RR fuel system, 6.0 trans cooler, Swamps IDM, HPX.
skylinedan is offline
post #7 of 14 (permalink) Old 11-29-2007, 05:03 PM
Jeepermc's Avatar
F-350's are twice as cool..........Honestly not a huge difference except the frontends as you know... Body styles for F-350 seem to be- Standard cab long bed and crew cab long bed only.. F-250 was available as standard cab LB, extra cab short and long bed and crew cab SB. It's possible there may have been special factory orders but I've not seen any....most are likely owner converted to 350 front end.
edit: for body configurations i'm talking 4x4 only. 2wd you could have an extended cab f-350
1997 F-350 PSD. Std Cab. Auto. IDM Mod, 1's,17* HPOP, TS-6 pos. tweaked by TW. ARB Bull bar, 8,000# Warn, IPF lights, 315/75/16 Toyo mud terrain.
Jeepermc is offline
post #8 of 14 (permalink) Old 11-29-2007, 05:06 PM
my dealer told me its 100 dollars (2003)
strokethis7.3 is offline
post #9 of 14 (permalink) Old 11-29-2007, 05:37 PM
OBS junkie
Cat_Rebel's Avatar
How many Supercab short bed F250 Powerstrokes were made? I know they were made in 96-97 like the crew short beds. I've seen two 2wds in my area but that's been about it. Every once in awhile I'll see one for sale but never that many of em. Seems like that's all that you ever see these days with the Superduty.
RIP Will Iott
post #10 of 14 (permalink) Old 12-01-2007, 12:02 AM
Jeepermc's Avatar
I think the supercab shortboxes are more rare then the crewcab shorties.....Don't see too many of either though..
Jeepermc is offline
