Locked out - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 06-25-2009, 02:28 AM Thread Starter
Locked out
My 97 CC door locks quite working. The drivers side is the only one that will open with the remote or button on door. If you try to open other doors there is a clicking sound, but the doors will not unlock. If you unlock the passenger side door with the key then it will lock from remote or door and you can also feel the rear also wanting to relock. The clicking sounds is coming from inside the door and also from under the dash by the remote keyless entry box. I have all screws out and button off, due you just pry the panel out of some clips. Anyone know what may be wrong. Thanks for any help!
2 Stroker is offline
post #2 of 4 (permalink) Old 06-25-2009, 02:33 AM
shake and bake baby!!
stroked350's Avatar
Re: Locked out
sounds like bad door lock actuators. there is a cheap fix for it on this website. check in the Library section. as far as the door panel goes just make sure you have all the screws out and pry. the clips can be a bear. go buy a panel popper it'll make life easier. good luck
2006 F-350 stock until warranty is up
stroked350 is offline
post #3 of 4 (permalink) Old 06-25-2009, 09:54 PM
All done now
Arisley's Avatar
Re: Locked out
Power Door Lock Fix - Powerstroke Nation
Here it is, that is if the OBS is like the SD.
Arisley is offline
post #4 of 4 (permalink) Old 06-25-2009, 10:51 PM Thread Starter
Re: Locked out
Well I got the panel popper and got the panel off. What do you have to take out, the whole door latch, 3 screws and some kind of a black tab that holds something if so do you drill it out or cut it off. thanks
